Cat 955 12a
1 year 1 month ago #251585 by Sssparks
Cat 955 12a was created by Sssparks
Hi, I have just purchased 955, there are a couple of issues and any help would be great.First the clutch lever will not stay locked in place when engaged and second the steering clutches are very heavy to operate, hopefully this is an adjustment issue, it's my first time with one of these and will be getting a service manual asap...thanks in advance anyassistance
1 year 1 month ago #251589 by gemdozer
Replied by gemdozer on topic Cat 955 12a
The 955 12a has a wet master cluch and should need a adjustement and check the stering cluch trunnion linkage for looseness
1 year 1 month ago #251626 by d9gdon
Replied by d9gdon on topic Cat 955 12a
If you join ACMOC, you can access the technical library that has the 955 12A manuals to show the clutch adjustment procedure.
1 year 1 month ago #251639 by Sssparks
Replied by Sssparks on topic Cat 955 12a
Thanks, I will have a look
1 year 1 month ago #251757 by Sssparks
Hi, it's actually the main clutch lever doesn't lock in place to drive the machine. Thanks
Time to create page: 0.274 seconds
