26x d5 sa injection pump
1 year 2 months ago #251302
by HUDCO
customer of mine thought their tractor was losing its prime at the throttle shaft cover so they took it off then they could not get it back on , i looked at it yesterday and they have pulled the shaft out some and somthing is off farther inside so th shaft will not go in far enough to go together i will have my local dealer help me get back on the sis so i can start getting parts looked up how much pump will i have to take apart fix it , is their a pump manual for if their is what is the part number
Thank you received: 818
1 year 2 months ago - 1 year 2 months ago #251306
If you pull the shaft out lever #1 drops off the shaft. You will need to pull the front cover to gain access to put it back together. While your in there you should replace the two seals (#10) and probably some gaskets.
Busso20
1 year 2 months ago #251310
by HUDCO
i am sure thats what has happened 15 and 16 is in front of #14 facing front to back of the pump correct is the seal behind the plate the same as 10 when i was looking at it ilooks like it will have to bee split right be hind the camshaft part of the pump
1 year 2 months ago #251318
by HUDCO
what about #2 dowel will it fall out in to some where bad ? i will get parts ordered to dayand wont get back to it untill i a ready to put it together , it is hooked a big double offset disc
1 year 2 months ago #251321
Should look like this in there when you put it back together. There are actually two levers on that shaft.
seiscat
1 year 2 months ago #251324
by HUDCO
thank you for your time spent, that is looking from the back of the pump and it is upside down on your work bench correct ?. you have no idea how much time this will save me out in the field and our customer, thay will have shop work for us this winter to keep the bills paid and my hired mechanics bills paid if we get slow, never does but i always worry about it. thanks hud
1 year 1 month ago #251538
by HUDCO
got the tractor back together this after noon had to much rain to get close to the tractor with the service truck for a few days it was areal pig to get bleed out but it that was about the best sounding engine i have heard for awhile and they were disking when i left the feild thanks for the help guys
