D4 pony carb doesn't respond to adjustment after refurbishment
Thank you received: 660
1 year 2 months ago #250937
Hi all, I cleaned out this carb (the bowl cross-passage and the emulsion tube included), fitted new gaskets and a new float valve and main jet. Set it up on my test stand pony and I can get it to idle, and can also get it to run at rated rpm for just a short while before it starts dying off. I adjusted the float to 1 1/16 which gives a high-ish fuel level in the bowl. The choking off after a couple of seconds of rated rpm sounds like it's starving so I need to deal with that, but what I also found was that adjusting the main jet seemed to have no effect on the running of the carb. This leads me to think that it is running on an alternate supply of gas. Can't quite remember what that alternate supply is called right now. I did replace the jet and I wonder if it's actually the wrong jet for that carb. I noticed that winding the jet screw in and out was very easy, as if it was not actually lifting the jet against the spring (it has the horizontal adjuster). I verified that the right angle toggle is engaged with the jet and I could see it adjusting when I had the top off the bowl.
Any thoughts on what I've missed? All gaskets are new including the bowl to throttle body gasket.
Thank you received: 788
Thank you received: 90
1 year 2 months ago #250940
by kittyman1
-what does sparkplug look like? (new one helps hugely)
-is it running lean? engine getting overly hot? not taking load?
-need to insure fuel supply is steady and adequate...
-otherwise my guess is passages still not clean enough...etc....
-or maybe not even fuel related? spark timing...etc...
-keep searching
Thank you received: 71
1 year 2 months ago - 1 year 2 months ago #250942
by Dandy Dave
Is the Carb bowl vent plugged? That will drive you nuts if it is. Usually will make the carburetor flood over but not always, or right away.
1940 Cat 12 Grader 6M17
1956 Cat D2-5U
1956 Cat D6- 9U 23721
Copake, NY.
kittyman1
1 year 2 months ago #250948
Thank you gentlemen, I'll recheck all these things. For reference, I first ran the pony with its original carb and it ran as expected - idle, accelerate, rated. Suspecting the problem being with the fuel bowl area, I swapped only the fuel bowl, and it gave teh same symptoms as when it was on its original throttle body and installed on my buddy's HT4. I will check the bowl venting arrangement. It's different to my 3J which has a breather - the HT4 carb does not have a visible external breather. It has a big stud in the bowl base where the drain plug usually goes - not clear why, possible the previous owner lost the plug and found a "will-fit". If the bowl is not venting properly, I could see problems with either a vacuum developing in there causing starvation, or drawing too much fuel in under vacuum causing flooding. Will investigate. Anyone happen to know what the "proper" venting arrangement is on these later model carbs without a side vent?
Thank you received: 818
1 year 2 months ago #250966
Turns out that I misdiagnosed the main jet adjuster bracket: it was quite bent and basically didn't move. I corrected that and now it runs but I'm still iffy on the float level. I'll try it under load and see what it does. The test stand is good but I can't load the pony which is what I need next. Idles beautifully
1 year 2 months ago #250993
by kittyman1
Carb bowl Vent plugged....awesome DandyDave....i forgot about that one....! ? !
1 year 1 month ago #251572
by Mike Hudson
Hey Neil glad you are on a roll. I was just fixing to tell you that I am getting by with mine, but it runs really fast if I don’t throttle it down pretty good. I don’t believe the governor is working right or at all on my d2 I’m always on the wrong side to see it operate. And another thing I cut the gas off every time on it and somehow gas gets in the oil. I have to change oil really often I guess it’s getting in the while I’m running it. Only thing I can think of unless that little petcock isn’t shutting completely off. Pony’s are a hand ful.
1 year 1 month ago #251591
Another problem we're having is that the viton-tipped float needle seems to stick. This is a new float valve from MacDonald. Does anyone have a recommendation for a different float valve and seat?
