O. T. - Do what yer can with what yer got.
Thank you received: 915
1 year 2 weeks ago #250653
by Deas Plant.
Hi, Folks.
O. T. - some Eastern European and elsewhere 'ingenuity' making do with what they have:
Thank you received: 775
Thank you received: 88
1 year 1 week ago #250713
by kittyman1
Love it, that's shade tree engineering at it's best...and most of it works...and can be further modified/improved...who knows where it goes..
- at the race track....this is called...."run what you brung" ....nice!
1 year 1 week ago - 1 year 1 week ago #250716
we have a ronaldson & tippet stationary engine at home that had a cream can for a hopper as it was either tank cooled originally or the factory cast iron one broke.
it was a common adaptation of the fergueson TE20 and ford 9n tractors to have the baby ford v8 as the original 4cyl engines were a bit anaemic in the power dept.
a mate of mine mounted a isuzu 4jb1t engine in a old fergy chassis. it now has double the hp and nearly triple the torque.
1 year 1 week ago - 1 year 1 week ago #250719
by Deas Plant.
Hi, trainzkid88.
The last farmer I worked for just after I left school had a Ford 80-donkey 6banger slotted into a Chamberlain 40K tractor and fitted it with dual rear wheels at the same time. That was quite the beast for its time.
I have done several truck re-powers, a 6V-71 Jimmy into an ACCO in place of a 6V-53 and a Cummins 903 V8 into a 1923 cab0over Benz amongst them. The Benz was good for 100 MILES PER HOUR PLUS after the re-power. I also slotted a 308 Holden V8 into an RLHC Bedford 4WD truck. That made it get up and boogie. I also put a TK Bedford cab on it and 'tilted' it while I was at it.
I also put an HB Holden Torana motor into an LJ50 Suzuki and then followed that one with a Datsun 1200 motor into another LJ50.
All good, clean(?) fun.
Last edit: 1 year 1 week ago by
Deas Plant.. Reason: add info.
1 year 1 week ago #250721
by Deas Plant.
Hi, Folks.
More on doin' what yer can with what yer got - check out the cushion blade on the push cat in this video - and the 'push cat' itself:
Just my 0.02
1 year 1 week ago #250722
one of the weirdest i saw was a home made "tractor" called old rusty. she was made from the arse end of a centurion tank and some rsj beams had a twin steer front end, a six cyl ruston developing around 1500 hp at 600 revs and 6 44 gal drums for a fuel tank. it had 6 30inch tractor wheels on the back.
at the same event there was a articulated chamberlain made from 2 super 90's with gm power that still got regular use in farming. it also had duals.
1 year 1 week ago - 1 year 1 week ago #250723
by Deas Plant.
Hi, trainzkid88.
Is this the one you mean?
And then there's this one, with a bit more footprint on the ground and a bit more grunt under the hoodz:
And a 'different' IH rig:
And two old 'poppin' Billys along with the Chamberlain unit(s) - before they got their extra back 'legs':
Or the Jackie Boy:
And the Black Jack:
And the Honey Bee:
And the Baldwin DP600:
And a converted Bren Gun Carrier:
And the Upton tractor:
And the 'grandmummy of them all:
Will that do for starterz?
1 year 1 week ago #250747
by kittyman1
that's great stuff Deas...110% correct on INGENUITY...
-also add a dash of Creative Flare,...and Human Spirit...awesome!
1 year 1 week ago - 1 year 1 week ago #250748
by Deas Plant.
Hi, kittyman1.
I just realized that I 'miscued' on one of those links. Where it showed the HoneyBee tractor twice, the second one was suppsed to be the Zell 214 foot seeder set-up bing pulled by a Baldwin DP600 tractor. I think I have corrected it now.
Part of the interest in that set-up is the way the GPS works. It either tells the driver where to steer the tractor so that the seeder misses the clump of trees - or - it doesn't trust the driver to do it and does the job itself.
