Hello Everyone, I just bought my first Cat, a 12, 8T, missed the oil clutch by 390 serial numbers, #15971, to grade the road to my house and my neighbors. My story is like many others which I’ve found out after reading the threads here and watching many videos online. I saved this old girl from the scrap yard, literally by a day. I had spoken to the owner about 3 months earlier, found him on Craigslist, had a JD grader that I looked at, no way that it was going to run, way to many parts missing, he comes across projects, picks them up, does a little work and then sells them. He told me if I’m not in a hurry to stop back and see how he’s doing with one of the Cats he had. He has a lot of projects, and I found out later the county thinks he has way too many. Anyway, gave him some time, and then I decided to stop back by and see how things were going. In between time the county had told him he needed to get rid of some stuff or he was getting fined. When I pulled up I saw the two other Cat 12’s that he had there, were getting gas axed and loaded on a trailer. Holy crap Batman! We did some horse trading right then and there, bought her a stay of execution for a week while I devised a plan to get her running and out of there in one piece. I think the Good Lord was watching out for me and said stop by and say hi, one more day and she would have been gone. So I got her running, no not with the pony, that’s why he couldn’t get the machine running, and not enough time. I got a 24 volt starter from George at Autolec, he was very helpful, he got the starter to me quick, I didn’t have much time. Found good info here on the forum, and she was ready with the factory hole in the bell housing for the starter! Getting the pony running in the future is something I’ll try to do. So, with all the fluids checked, new fuel, fuel filters, starter, and the fuel lines bled, she fired right up as advertised! With just an hour to spare, the truck showed, we loaded up and got her home. So now there’s not the emergency to get her moved, safe from the gas axe, I now have time to go through and give her some love, got all the manuals from eBay so I know what I’m doing, well kinda, changed out all the fluids and filters, put new gauges in, they were all broke, new seals in a couple of places to fix some hydraulic leaks, cleaning and lots of greasing. Here’s where I’m needing some guidance/advice. I pulled the wheels to get some different rubber, they all were dry rotted, as I was pulling the right rear I noticed the wheel hub was loose. See the photos where I drew a line to see how much it moved, about 1/2 to 3/4 inch. From reading the threads talking about brakes on these machines, the hubs need to be dry fit on to the spindle with 30 tons of pressure, or there’s going to be some damage. This is where I got a little bit of a pit in my stomach. I got a 24” pipe wrench, I know! It’s all I had out here in the desert and got the nut off, I’ve got a socket on order. The hub and drum came right off. I think the hubs were pulled at one time for brakes, looking at how good of shape the pads are in, and the hub didn’t get put back on the right way. Just a guess, not sure about the other, it seems tight, but that’s in question. I’ve got lots of pictures of the inside, the slot on the one side of the spindle looks tight, the key stays in while pushed in from underneath, doesn’t fall out. But is the key long enough, it seems short, 4 inches? The slot in the hub doesn’t look so good, can that be fixed? Welded and machined, or is a new used hub the fix? The nut threads all the way on smoothly but it looks like I need to file the end of the spindle where there are a couple of points at the end. The nut didn’t seem tight to the hub, there was a little space, those metal burrs look like it could be holding the nut out. Is the shaft okay? Finally, what’s the correct way to get the hub pressed back on, methods / tools, can I do it or do I need to call a field truck with hydraulic equipment. I hope I caught this in time, and no other damage was done. Other than this, everything has checked out, she’s in good shape! I want to take care of this machine, give her some new paint as time permits and keep her running for years to come. Thank you in advance, any help will be greatly appreciated.
