171 Hydraulic Control??
Thank you received: 34
1 year 3 months ago #250460
by greengiant
What is a 171 Hydraulic Control and how do I tell if my D7E has it? The transmission oil drain procedure is different for ones with and without. The one with it has 3 more gallons of oil.
Thanks!
Thank you received: 818
1 year 3 months ago - 1 year 3 months ago #250462
The 171 Hydraulic Control consists of a fender mounted external (foot operated) control valve and a hydraulic pump. The control is used to operate a hydraulic blade tilt cylinder. The vane pump is mounted on the rear power take-off housing of the engine and is driven by the rear power take-off idler gear. The oil for the hydraulic control system is supplied from the tractor transmission and is cooled and filtered by the transmission oil system.
Thank you received: 347
1 year 3 months ago #250464
by seiscat
Go to the library and look at the D7E 16 page brochure I just put there yesterday. It has pictures of the all the hydraulic systems available for your tractor.
Craig
1 year 3 months ago #250468
by greengiant
thanks guys! mine is a 173. i had drained all the oil that i could find plugs for and then it occurred to me that if mine is a 171 i should have drained the hydraulic with the motor running first.
