Cat D7E Oil Types
1 year 3 months ago #250318 by nch77
Cat D7E Oil Types was created by nch77
I just picked up a Cat D7e, serial 48A1697 and I am looking for what oil type I can use for the engine. The manual I found calls out SAE 30, is modern split weight better? It starts and runs great, only a few leaks. Also, since the transmission looks pretty good should I change it or leave it alone and just change the filter? The transmission oil is leaking into the right hand final drive but not very quickly.
TIA
1 year 3 months ago #250322 by trainzkid88
Replied by trainzkid88 on topic Cat D7E Oil Types
modern multi grades are almost always superior. yes change all the oils and the filters. then you know its been done. its cheap insurance and check the filters and drain bungs for filings etc magnetic drain bungs are a good idea to show is there metal wear in something.
i would use delo gold 15w40 in the engine.
get in touch with your chosen oil company's tech advice line and get a recommended oils list for your machine. there is nothing really special about cat's own range of oils there made by one of the major oil companies and slap cat's label on their product.
1 year 3 months ago #250326 by dpendzic
Replied by dpendzic on topic Cat D7E Oil Types
somewhere i read that Mobil made all of Caterpillar oils
D2, D3, D4, D6, 941B, Cat 15
Hancock Ma and Moriches NY
1 year 3 months ago #250330 by greengiant
Replied by greengiant on topic Cat D7E Oil Types
How many drain plugs do you have NCH?
my book says 5 but I can find only 3: the bevel gear plug toward the back of the machine, and the steering clutch plugs. I can't find the torque converter housing plug (center toward the front) or the oil cooler plug.
I can't find the oil cooler. i know that on machines with electric starters its on the left just above the starter. but mine is a pony starter.
1 year 3 months ago #250340 by nch77
Replied by nch77 on topic Cat D7E Oil Types
I don't know, I haven't spent much time under the machine yet. I just got it delivered last week and haven't had the time.
1 year 3 months ago #250363 by greengiant
It's really quite pleasant under all that beautiful iron, especially nice and cool on a hot summer day.
1 year 3 months ago #250385 by nch77
How do I identify which hydraulic system I have between the 171 and 181 system?
1 year 3 months ago - 1 year 3 months ago #250395 by seiscat
Replied by seiscat on topic Cat D7E Oil Types
Early D7E options are below. 171 is for tilt with cable blade.
Craig
Last edit: 1 year 3 months ago by seiscat.
1 year 3 months ago #250461 by nch77
So I have the 181 with a separate tank? I have a large floor mounted lever on the right for the blade raise/lower and small lever on the left under the transmission control for tilt. There is a small tank on the floor on the right side too. But the radiator screen looks to have the 173 tank under it,
1 year 3 months ago #250465 by nch77
would I use the same oil in the transmission or use tractor transmission oil?
