D2 5J adding external fuel filter
1 year 4 months ago #249838
by vansgarage
Need to know the thread/fitting type and size on the fuel line, (and dia.), inlet to transfer pump, 5J- fender tank. Adding a canister CAV delphi filter. Want to make up in advance tractor is up in woods on the job. Thanks for any replies Joe Van.
Thank you received: 788
Thank you received: 121
1 year 4 months ago #249855
by PhilC
Don't know about the D2 but my D6's are all 1/2" lines.I think even the D8's are only 1/2 as well.
Thank you received: 660
Thank you received: 33
1 year 4 months ago #249868
by bcwayne
The fuel line is 1/2'' ID. Original was steel. The fitting at the transfer pump is 7/8'' x 14 tpi straight pipe thread... not tapered pipe thread. You can use a -10 O ring boss fitting into the pump, and your choice of fuel line or hose from there.
1 year 4 months ago #249872
by vansgarage
Thanks guys, I thought I remembered it being a straight thread, could not remember if there was a seat or 0 ring, I was pretty sure on the 1/2" steel line. I don't like using rubber due to varmints chewing on it. Thanks again. Joe Van.
Time to create page: 0.154 seconds
