D311 accessory drive.
1 year 4 months ago #249722 by mog5858
 Does anyone know if there's an HP rating on the accessory drive on the front of the D311? could one take off a generator and replace it with a hydraulic pump?   would like to have live hydraulics and don't want a pump hanging off the front.  thinking 5-8 GPM range probably would be a gear pump as they are cheap and simple.
1 year 4 months ago #249725 by juiceman
Replied by juiceman on topic D311 accessory drive.
I don't know the HP rating, but I have a U series D2 here with hydraulics adapted to it in place of the generator. Works just fine. I have/had a J series as well set up similar. JM
1 year 4 months ago #249726 by Busso20
Replied by Busso20 on topic D311 accessory drive.
JM would you be able to show a picture of the set up? sounds interesting and what do you power with it? my 3J has rear PTO with sprocket and chain to drive pump, never seen engine drive train doing the work.
Cheers Jamie
1 year 4 months ago #249734 by juiceman
I can take a photo of it when I can remember which building I parked it in! I will gladly go look for it today, and get out of the heat.
The 5U came to me with it already installed; not the prettiest set up, but it works well. The tractor has been used to pull hydraulic controlled disks and orchard levelers.
The previous owner said it was "field engineered" by some old tractor hand. I will reply later today. JM
The following user(s) said Thank You: Busso20
1 year 4 months ago #249739 by juiceman
Okay, it was inside the diesel dungeon here.
The following user(s) said Thank You: gauntjoh, rax200, Haus, ChrisRoyd2, Busso20
1 year 4 months ago #249746 by mog5858
Replied by mog5858 on topic D311 accessory drive.
thanks JM that's what I had in my head doesn't look too bad at all. so I guess that answer my question that it will work. somedays I wonder as there's a lot of ideas floating around up there.
1 year 4 months ago #249772 by D4Jim
Replied by D4Jim on topic D311 accessory drive.
Gosh Gee I thought my eyes had gone out of "kilter" seeing all the yellow in that one photo. Thanks for posting.
ACMOC Member 27 years
D47U 1950 #10164
Cat 112 1949 #3U1457
Cat 40 Scraper #1W-5494
1 year 4 months ago #249782 by Busso20
Nice arrangement for the pump and looks very good, at least live power at hand, nice to see all the machines in under cover, a life time of history and stories there
1 year 4 months ago #249795 by HUDCO
Replied by HUDCO on topic D311 accessory drive.
juiceman what does that allis hd6 compare to caterpillar modal wise ?
1 year 4 months ago #249797 by wimmera farmer
Please put a relief valve in the system. I kow of a D318(D8U) that was set up very neatly untill they deadheaded the pump . That wrecked some timing gears real quick.
cheers WF
