D311 accessory drive.
Thank you received: 84
1 year 4 months ago #249722
by mog5858
Does anyone know if there's an HP rating on the accessory drive on the front of the D311? could one take off a generator and replace it with a hydraulic pump? would like to have live hydraulics and don't want a pump hanging off the front. thinking 5-8 GPM range probably would be a gear pump as they are cheap and simple.
Thank you received: 774
1 year 4 months ago #249725
by juiceman
I don't know the HP rating, but I have a U series D2 here with hydraulics adapted to it in place of the generator. Works just fine. I have/had a J series as well set up similar. JM
Thank you received: 41
1 year 4 months ago #249726
by Busso20
JM would you be able to show a picture of the set up? sounds interesting and what do you power with it? my 3J has rear PTO with sprocket and chain to drive pump, never seen engine drive train doing the work.
Cheers Jamie
1 year 4 months ago #249734
by juiceman
I can take a photo of it when I can remember which building I parked it in! I will gladly go look for it today, and get out of the heat.
The 5U came to me with it already installed; not the prettiest set up, but it works well. The tractor has been used to pull hydraulic controlled disks and orchard levelers.
The previous owner said it was "field engineered" by some old tractor hand. I will reply later today. JM
Busso20
1 year 4 months ago #249746
by mog5858
thanks JM that's what I had in my head doesn't look too bad at all. so I guess that answer my question that it will work. somedays I wonder as there's a lot of ideas floating around up there.
Thank you received: 405
1 year 4 months ago #249772
by D4Jim
Gosh Gee I thought my eyes had gone out of "kilter" seeing all the yellow in that one photo. Thanks for posting.
ACMOC Member 27 years
D47U 1950 #10164
Cat 112 1949 #3U1457
Cat 40 Scraper #1W-5494
1 year 4 months ago #249782
by Busso20
Nice arrangement for the pump and looks very good, at least live power at hand, nice to see all the machines in under cover, a life time of history and stories there
1 year 4 months ago #249797
by wimmera farmer
Please put a relief valve in the system. I kow of a D318(D8U) that was set up very neatly untill they deadheaded the pump . That wrecked some timing gears real quick.
cheers WF
Time to create page: 0.201 seconds
