Rust in Diesel Tank
1 year 4 months ago #249597 by neil
Replied by neil on topic Rust in Diesel Tank
I can't remember but I do know that you can vary it depending on how strong you want it. I want to say maybe 2-5# in a five gallon bucket. Muriatic acid also works well (probably better than citric) but it requires more careful handling because it has a lower pH and is generally sold in a concentrated ready-to-use form which means you probably want to dilute it, and strong acids like muriatic need to be diluted in a certain sequence - fill plastic (non-metal) bucket with water then add acid to it, not the other way round. Citric is sold online in powder form for you to mix up. It's also the acid in lemons etc. so it's a lot more human-compatible than muriatic, even though we all have hydrochloric acid in our stomachs (muriatic is a form of hydrochoric acid HCl). Unless you feel comfortable using muriatic, your safer bet would be to use citric.
The following user(s) said Thank You: sheddcanyon, Fat Dan
1 year 4 months ago - 1 year 4 months ago #249603 by trainzkid88
Replied by trainzkid88 on topic Rust in Diesel Tank
all acids and caustics are to be mixed that way. because they react violently with water and its a exothermic reaction it gives off fumes so do it outside and keep your head out of the fumes wear acid resistant gloves,boots,apron and face shield.
muriatic acid is also known as hydrochloric acid. its main use domestically is as acid in swimming pools. ironically the human body produces it in our stomach its what breaks down food we eat.
all concentrated acids are dangerous. yet diluted forms are harder to store. 90 percent sulphuric acid is stored in stainless steel tanks yet 80 percent of less cant be because its so strong it forms a oxide layer so quick it stops eating it away but a diluted solution can penetrate the oxide layer
the best acid to use is phosphoric acid or tannic acid as it will chemically stop the rust and change the iron oxide from to iron phosphate or iron tannate. both are commercially available as rust converter products. ranex rustbuster or fertan. no mixing needed there ready to use products. pour in and rotate so all sides are treated letting it dwell on each side for a few minutes before tipping out the excess and letting it dry for a couple of days.
Last edit: 1 year 4 months ago by trainzkid88.
Time to create page: 0.137 seconds
