7U D4 Hydraulic hose connector replacement?
Thank you received: 7
1 year 4 months ago #249487
by toddsmith23
Hello -
I'm looking for replacement hydraulic hose connectors for my d4. The originals are rusted through and need replacing. Hoping someone can tell me the mfg/part number for a good working replacements. I believe the originals are a -12 code 61 o-ring faced straight flange. Wondering if there's a conversion to JIC?
Help much appreciated!
-Todd
Thank you received: 60
1 year 4 months ago #249502
by PNW.Hillbilly
If the original 2-bolt flanges are still in good condition, you can make a crimped hose using CAT fitting part# 124-2052 or equivalent (just make sure you put the flanges on before crimping the hose ends). Picture below shows that. If your flanges are rusted out, you will probably have to find a new ones, not aware of any way to convert over to a 4-bolt flange code 61. Maybe someone else is though.
Thank you received: 788
1 year 4 months ago #249512
those fitting are still available but they are crimp on rather than bolt on. yes there sae code 61 dash 12 size.
any hose service can make you new hoses they will need to reuse the flange plates from the original hoses. if the flanges are damaged you can make your own if you have a milling machine there only medium tensile steel. these old girls have a max working pressure of 1500 psi.
you local cat dealer can also make them for you
just take the old hoses as a template.
dont forget to get new seals too
you can get adapter to jic fittings. but why bother crimp fittings arent that expensive. the only advantage is if you use field attachable jic fittings you can change you own hoses on site without a portable crimp machine.
1 year 4 months ago #249513
by toddsmith23
this is exactly what i want!! My plates (2 bolt flange plates) are in good condition. the hose barb is rusted through and is junk.
thanks for the help, i'll bring the hoses down to the local hydraulic shop and have a few made up.
Thanks!!!
Time to create page: 0.147 seconds
