F/R lever stuck in reverse
1 year 5 months ago #249047 by TomsD4d
Hi all!  New to the site,thought I’d try to pick up some good info here seems like the right place to be! Recently purchased a D4d serial #78A7492 Tranny Group 5k8017 runs well but was wondering about the model year . It will go in reverse only F/R lever  stuck Should I pull the inspection covers for the steering clutches or am I barking up the wrong tree! Any help would be greatly appreciated!
1 year 5 months ago #249054 by trainzkid88
could be just stiff mechanisims. try some penertrating oil on the linkages.
The following user(s) said Thank You: Fat Dan, TomsD4d
1 year 5 months ago #249081 by wimmera farmer
Not sure about a D4D setup but I assume there is an interlock with the cluch lever to lock the transmission in gear when the clutch is engaged. I would start by making sure that is working correctly.You really need a servicmans reference book for that model or at least a copy of that section.
1 year 5 months ago #249085 by Deas Plant.
Hi, TomsD4d.
If the F/R lever is STUCK in reverse, I would look first at the interlock mechanism that wimmera farmer mentioned but I would also check to see that nothing become wedged in there somewhere to jam the lever - although I think that control goes straight into the transmission case with no linkage.
How-wevver, if it comes out of reverse to neutral but will not go into forward, that may well be something inside the transmission, although not entirely ruling out the interlocks there either.
1 year 5 months ago #249160 by Fat Dan
Replied by Fat Dan on topic F/R lever stuck in reverse
The 78A prefix approximately starting shipping out in 1963. So #78A-7492 is most likely 1963-1964. Best I can do
ACMOC Member
1 year 4 months ago #249560 by 74A6C
Replied by 74A6C on topic F/R lever stuck in reverse
If a 4D trans is anything like the 6C, the interlock mechanism consists of a cover holding a shaft and a series of springs and plungers. No huge task to remove and clean up, but depending on the configuration of your tractor, may be a pain to access, like the one on my 6C. A broken spring or plunger could hang things up
Time to create page: 0.148 seconds
