D4 7J main clutch
D4 7J main clutch
Thank you received: 5
1 year 5 months ago #248967
by Tad7561
So my D4 7J needs a new clutch collar, brass shavings everywhere inside and I got a 10’ disk that my D2 won’t pull well. Can you change the collar without pulling the engine? I know to change out the clutch you need to. But I need to do just the collar.
Thank you received: 46
1 year 5 months ago #248975
by ChuckC
What kind of disk do you have? I had a 13' RWA John Deere disk that I pulled with my 5UD2 in 4th gear. You must have a big disked offset disk.
Chcck C
Thank you received: 788
1 year 5 months ago #248977
remember discks are sized by the number off plates(discs) yes disc size makes a difference but not as much as the shear number of them.
1 year 5 months ago - 1 year 5 months ago #248986
by Tad7561
10’ offset with 18” blades, my D2 5J struggles with an 8’ offset. We don’t plow and don’t use a tandem. We use heavy offset disks One pass breaks and cuts in whatever I need it to.
Last edit: 1 year 5 months ago by
Tad7561.
1 year 5 months ago #248988
by Tad7561
No if I barely had the disk cutting I’d pull it with my farmall H. I need to cut fire breaks every year here.
Thank you received: 47
1 year 5 months ago #248990
by 8C 361
I was able to change the clutch collar on an early 7U through small top cover. I got it from a 5T parts tractor. Everything was the same.
Used to pull 6' 9" disc with D2. Pulled 10' 6" offset with D4 but a little much in the hills. 9' 0" is about right but had to find anymore.
1 year 5 months ago - 1 year 5 months ago #248995
by Tad7561
Was hoping the collar could be changed through top access hole, thank you. This disk is all both my D2 can handle and this is the setting I have it and yes the disk is beat.
Tad7561.
1 year 5 months ago #249014
by ChuckC
The pictures explain why the D2 would not pull it. I don't think my D2 would pull it either. Thanks for clearing that up.
1 year 5 months ago #249016
by 8C 361
Il bet if you closed it up some more and chained it that D2 would pull it and it would still chop up the ground pretty good.
D4 7J main clutch
