12 8T1 intro
1 year 5 months ago #248905 by Denis85
12 8T1 intro was created by Denis85
going to road it home wednesday 60 miles
what year is it?  would it have the hole for 12v starter conversion?
if not, what is the best way to go?
1 year 5 months ago #248911 by seyser
Replied by seyser on topic 12 8T1 intro
The grader is a 1955.
The following user(s) said Thank You: Fat Dan, Denis85
1 year 5 months ago #248912 by Old Magnet
Replied by Old Magnet on topic 12 8T1 intro
Looks like you just made it with Direct Start provision starting s/n 8T15689
1 year 5 months ago #248958 by Denis85
Replied by Denis85 on topic 12 8T1 intro
got it home.  it does run 20 on the flat, less uphill, and too fast downhill - bounce!
cracked the bottom right door glass on the way home.   is that something a local glass shop can fix?
 the steering box weeped out the oil and gunk from the top. unknown cause
unfortunately the block doesn’t have the direct start provision.  can’t find the sticky about the conversion. did find some info for the companies in tx. and mo.
the engine has a newer serial number.
there are no digits in the window for the hour meter
The following user(s) said Thank You: Deas Plant., Fat Dan
1 year 5 months ago #248959 by kracked1
Replied by kracked1 on topic 12 8T1 intro
The engine is way older, not newer. The power steering box needs to be resealed. there is a cheat that can be done. You remove the vent and run a hose from the hole to the hydraulic tank to recirculate the oil. The door glass can be done by any glass shop.
1 year 5 months ago #248968 by HUDCO
Replied by HUDCO on topic 12 8T1 intro
we are diong an 8t 3517 the pony motor has bad rod and crank i try that guys phone number for the direct elictric start and it did not work
1 year 5 months ago #248969 by Denis85
this might work
1 year 5 months ago #249076 by Fat Dan
Replied by Fat Dan on topic 12 8T1 intro
Sweet find 🤗
ACMOC Member
1 year 5 months ago #249083 by Delta KJ
Replied by Delta KJ on topic 12 8T1 intro
I agree that it looks like a nice grader... scarifier and nice rubber!
I recently replaced some windows in my No. 12. Had the laminated glass (1/4") cut into rectangles and then cut the curves myself (to do it again I would have the glass company cut the curves).
The hard part was finding suitable rubber glass molding.
1 year 5 months ago #249098 by Dandy Dave
Replied by Dandy Dave on topic 12 8T1 intro
The engine is 1949. The reason for the raised area casted in the bell housing is because the Cat Model 12-6M series had direct electric start for the G4600 engine. Only 56 were built. Yours is a D318.
1940 Cat 12 Grader 6M17
1956 Cat D2-5U
1956 Cat D6- 9U 23721
Copake, NY.
