933f caterpillar pressing final drive components
Thank you received: 6
1 year 5 months ago #248888
by Arkie
I'm down to pressing the steering clutches and I've seen a very detailed video that shows a hollow ram and threaded rod to press the clutches. My issue is the end of the steering shaft isn't threaded. I'll have the same issue pressing the sprockets as the sprocket shafts aren't threaded either. Am I missing something? The video shows a D2 but the 933 manual appears to show the same process. As always thanks for your input.
Thank you received: 60
1 year 5 months ago #248902
by Arkie
Here's pics of the steering shaft but it'll be this evening before I can get sprocket shaft pictures.
Thank you received: 124
1 year 5 months ago - 1 year 5 months ago #248904
by PNW.Hillbilly
How is the nut still on there when you have the hub removed??? Did the hub come off in pieces? Is that a chunk of the hub behind the nut? It almost looks like the hub got pulled off without removing the nut, removing a section of the hub in the process...
1 year 5 months ago #248907
by side-seat
PNW Hillbilly
Looks like he's attempting to remove the ring gear if those bearing hubs are off. I think that is a heavy washer under the nut.
1 year 5 months ago #248908
by Arkie
The clutch pack is still together. The picture just happens to have the nut on it by chance with the washer that gets bent over when torqued down. I've rebuilt the clutch packs and ready to press them on but even using a scratch awl, I can't feel or see threads in the steering shaft or sprocket shaft. I'll dig deeper when I'm home. Thank you for responding
Thank you received: 660
1 year 5 months ago #248910
Same process for pushing and pulling the sprocket. I bought a nut that was deep enough to engage all the threads on the shaft rather than the thin cap nut and used it to both push and pull depending on how I set my hollow ram and associated adaptors.
