D7C brake sticking
1 year 6 months ago #248359 by rustyfender
My D7 s/n 17A 5563, brake has been sticking for a year or so, works fine, just have to push pedal hard and pull it back by hand, seems worse after machine is up to operating temperature. I have looked inside brake compartment, sprayed all pivot points , seemed to look normal. This is on the right side sitting on the seat.
1 year 6 months ago #248370 by seiscat
Replied by seiscat on topic D7C brake sticking
Probably worn shaft/bushing of the brake pedal. This allows dirt/rust to build up and cause the sticking. Take the pedal off and just clean it up for a temporary fix.
Craig
1 year 6 months ago #248371 by rustyfender
Replied by rustyfender on topic D7C brake sticking
I have unhooked the pedal mechanism and lubed it and it moves free, problem must be inside the housing so where.
1 year 6 months ago #248377 by seiscat
The parts book I have is for D7D 17A11,879 to 19,442 Sorry. Maybe Old Magnet or someone else on the forum will help.
Good luck,
Craig
The following user(s) said Thank You: rustyfender
1 year 6 months ago #248505 by rustyfender
It seems to be stuck where the pedal rod goes through the steering clutch housing
Time to create page: 0.143 seconds
