What can I do?
What can I do?
Thank you received: 7
1 year 6 months ago #248035
by gwoods
I have just finished removing cover over clutch, gears, brake system from d4 7u / 7U11300. I need free up main clutch and the pinion engagement. Any suggestions on the best way to accomplish? What should I check on the brakes since they are in sight? Does anyone have suggestions on cleaner that not harmful to breath. I hope I send three picks with this.
Gary Woods
Thank you received: 502
1 year 6 months ago #248045
by ctsnowfighter
Gary - great question!
NOT HARMFUL to BREATHE --- CLEAN PURE AIR -- is the correct answer.
By mass and exposure routes, skin is large, Lungs are HUGE, anything you can do to protect yourself from inhalation is a plus.
IF you are speaking solvents, soaps, degreasers, etc - you do not want any of those contacting your lungs!
Lung protection depends upon materials and the proper PPE --- PERSONAL PROTECTIVE EQUIPMENT -- AND THAT MEANS APPROVED FOR THE VARIOUS CHEMICALS AND COMPOUNDS EXPOSED TO THE USER.
Some simple compounds/chemicals attack certain aspects of our systems and some are long term effects from short term exposure.
STAY SAFE --- ONLY YOU CAN PROTECT YOURSELF!
Remember the routes of exposure --- INHALATION, DERMAL, OCCULAR, INJECTION. EYES ARE VERY suseptable to rapid absorption.
(years of training in Hazardous Materials Emergency Response did teach me a little - I hope this helps others here)
CTS
Thank you received: 788
1 year 6 months ago #248056
the fastest route of exposure other the breathing or swallowing is the eyes.
im a licenced ag chemicals applicator.
the simplest and best is solvent based quick break degreaser in aerosol cans or by the drum with cheap paint brush/parts brush and a jam tin do wear gloves preferably nitrile as there solvent resistant i used both aerosol is easy to apply brush application is better for crusted on grime. and dont forget a scraper/putty knife.
to clean before painting after all the grease and crap is removed with solvent degreaser. i use a water based degreaser called shock treatment made by chemtech you use it in dilute form dont let it dry particularly on aluminium as it is caustic and it can attack paint a little.
Thank you received: 321
1 year 6 months ago #248059
by Ray54
OH the good old days of a siphon gun on the air hose and a gas can. An I never saw it go K BOOM.
1 year 6 months ago #248071
by gwoods
Thank you for the suggested explanation products that are safe use. Safety is a prime concern when enjoying working on a machine that can be brought back to life.
Gary Woods
1 year 6 months ago #248076
as you can seethe brak assembly look for wear in the linkage and that it works as it should, buildup of water or corrosion in the housing. a little squirt of spray grease into the pivot points on the linkages. just bassically a good visually inspection of everything. and adjust things to spec.
1 year 6 months ago #248088
by gwoods
I have got brake pivot points loose, I got the clutch engagement gear to release. ( how in the world is those two with all the teeth engage without grinding?) I like the idea of not going any farther in tear down. So your thought transkid88 is to spray the clutch moving parts with grease. What about where the teeth are on clutch and motor flywheel? I may use the wrong technical terms out of ignorance. The dozer is thought to have a problem with left side final drive, I have yet got to that problem. As you can see I need all the help possible.
Gary Woods
1 year 6 months ago #248101
just a little bit. but use a penetrating oil such as bolt off or yield first. use spairingly.
the toothed plates are the pressure plates the actual friction disks are in between.
Thank you received: 121
1 year 6 months ago #248104
by PhilC
Other way around champion.For the steering clutches the plates with outer teeth have the friction material on them and the plates with inner teeth have no lining. NONE are pressure plates, the pressure plates are on each end, one is part of the inner drum and the other is a floating plate under spring tension. For the main clutch the flywheel has teeth that the clutch plate with outer teeth slides in, The pressure plates are separate to the flywheel unlike most normal clutches that use the flywheel as one side of the pressure plate.
Spraying grease all over the linkages will do little or nothing to lubricate the various pivot points. You are far better off using a penetrating oil but make sure you do not get any on the brake drums and the friction plates.
I would be looking into your issue with the final drive first before you spend any money on any of the rest. If there has been a catastrophic failure in the final gears that has damaged the housing then it might only be a parts machine.
What can I do?
Time to create page: 0.188 seconds
