944 compressor
1 year 6 months ago - 1 year 6 months ago #247976 by PhilC
944 compressor was created by PhilC
Hello All
The compressor on my 944 stopped working and upon disassembly I found the inlet valve springs broken and the outlet valve springs have lost tension. Valves themselves look fine. The compressor is an air cooled Bendix Tu-flow 300 which are discontinued and parts are non existent from Cat.Bendix don't even list them anymore.
Has anyone had this issue before and found a workaround? I have heard some say to replace it with a Tu-flow 400 but I think it has a longer housing than the 300.
Regards
Phil
Last edit: 1 year 6 months ago by PhilC.
1 year 6 months ago #248015 by trainzkid88
Replied by trainzkid88 on topic 944 compressor
could the valve springs be the same in the later model pump? although without a parts list it would be hard to tell. if you could find the spec sheet for the parts for the later unit you could atleast compare to the old parts. it might be a way of getting your working again.
1 year 6 months ago #248018 by PhilC
Replied by PhilC on topic 944 compressor
First thing I checked.Totally different. Different springs, different valves.
1 year 6 months ago #248022 by trainzkid88
bugger. does the spec sheet give dimensions of the whole unit you coul at least see if it would clear before shelling out the folding stuff on a pump.
Time to create page: 0.156 seconds
