D25u pinion Engagement
Thank you received: 774
1 year 7 months ago #247189
by juiceman
Steve1ac: Drain the pony heads first; squirt some lube inside the spark plug holes; make a turning bar for the rope pulley and try and rock it back and forth. I have had pony motors that just had a sticky piston from sitting, nothing wrong with engine, just needed some "persuasion" from many years of sitting. You are on the right track. Good luck. JM
Thank you received: 82
1 year 7 months ago #247190
by bernie
Sounds like Main Flywheel Clutch may be out of adjustment.
Also-suggest to avoid the temptation of regularly starting Main by holding pinion lever up. A lot of posts suggesting avoiding that.
As for the latches letting go early, it can only take a quick “bark” of the diesel for those to unlatch. Could be just one is out of adjustment if someone in the past didn’t set them correctly.
Have fun-keep safe
Thank you received: 9
1 year 7 months ago #247197
by Steve1ac
Thanks juiceman for the
The pony and the main engine are two would appear to be well running motors
1 year 7 months ago #247198
by Steve1ac
Thanks Bernie
Serial number 5u17156 It is a D2
just short of me going down to the homeplace and digging out all the manuals that dad had for this machine, would you be able to basically say what it takes to adjust this main clutch
I’ve got Allis charmers antique tractors crawl under it remove the plate expose Fly wheel and adjust forks this process is pretty Simple
I can remember one or two projects that dad and I did on this machine nothing was simple.
Thank you received: 663
1 year 7 months ago #247201
Yes, the problem is it seems some Cat designers never had to actually work on their own designs as mechanics. If they had had to spend a year in a workshop, the designs would have been much more service-friendly I'm sure.
1 year 7 months ago - 1 year 7 months ago #247202
To Neil thanks Just short of me leaving through all this material than dad had
On your fly wheel removal, socket and impact nut off then did you need or make some kind of puller to remove fly wheel
How many d2 s. do you have
You're welcome Steve. For flywheel removal, yes an impact and 1/2" rattler will get the nut off after flattening the lock washer. You definitely need a puller that screws into the two holes on the flywheel and bears against the crankshaft pilot. I have an OTC with a straight slotted bar and I thread I think it's 3/8NF bolts into the flywheel. Do not under any circumstances pound axially on the pony crank or flywheel, because the main bearings that maintain axial clearance are only retained by a pair of small dowels through the soft aluminum bearings. I have two D2s: a 3J4086 and 5U13753. It's not going to kill the tractor if you have to hold the pinion engagement up a couple of times but that really is just a few times - if you have to hold it, plan a weekend in the next one-to-two weeks to address the issue so you get it done
Last edit: 1 year 7 months ago by
neil. Reason: More info
Steve1ac
Thank you received: 788
1 year 7 months ago #247216
the grinding is either the clutch isnt releasing properly due to out of adjustment or excess wear. or you moving to quickly to engage a gear. yes adjust the pinion latches it best if they are working properly.
1 year 7 months ago #247241
by cojhl2
You must engage the clutch brake on Caterpillars to properly engage gears from neutral. This does not indicate clutch out of adjustment.
9U(2), 5J, IHC544, Ford860
1 year 7 months ago #247248
i wasnt sure if they did have a clutch brake or not. i assume you push the clutch lever forward to use it.
1 year 7 months ago #247311
by Steve1ac
Thanks cojhl2 I was pushing it forward and couldn’t seem to get it to break and or stop spinning to be able to shift
Time to create page: 0.194 seconds
