CAT D5 injection pump problems/options
1 year 7 months ago #247051 by Quadrajet2000
Got a 1971 D5 D333C engine with a crankcase full of fuel.  Anyone know if the newer sleeve metering pump and transfer pump for pc engines will fix the problem or even fit my engine?  Seems the scroll pumps or their transfer/lift pump counterpart are notorious for leaking into the oil and I don't want to mess with rebuilding something that's problematic for destroying engines.
1 year 7 months ago #247071 by Ray54
Not familiar with your fuel pump, but if the seals are just o rings like the previous style that I have been in, it is no big deal to fix. Just a very good habit to check all the dip sticks on this older stuff every day when you start, so thinning of oil by fuel should show up long before you have a problem. But since I don't know hopefully moving you back to the top gets you more real information.
The following user(s) said Thank You: Quadrajet2000
1 year 7 months ago - 1 year 7 months ago #247075 by Old Magnet
What's the actual s/n? 1971 is the cross over year from the D333c's to 3306.
I would advise staying with the scroll pump. Cat has gone full circle back to scroll pumps as sleeve metering pumps were not without problems. The old style fuel transfer pump has the upgraded lip type seals over the old packing type. The fuel filter connection to the injection pump fuel gallery is an external connection where any leakage is visible and does not leak to the oil sump. About the only place you could get oil contamination is if you have leakage past the individual pumps which is possible but not very likely and yes, change the transfer pump seals and check the shaft for wear from the seals..
Last edit: 1 year 7 months ago by Old Magnet.
1 year 7 months ago #247077 by Quadrajet2000
Not 100% sure of the year but my serial is 96J2347 both tractor and engine tag.  Makes me feel a little better about my situation.   I've not got the pump apart yet but a previous owner did remove little drain on the bottom of the transfer pump and caped it with a pipe plug so that's definitely one leak issue masked.
Thank you for helping me out on this.
1 year 7 months ago #247080 by trainzkid88
todays fuel is what cuases most of these things to start leaking. the ultra low sulphur doest lubricate the same and it also hardens the seals a bit. new seals are more resistant as they tend to use viton rather than nitrile rubber. and any good pump shop can have them done in a few days. when we had the injection pump done for the old mans ute it came back with a new lease of life and used less fuel and it ran better too as it was getting correct fuel load. yes you can modify pumps but its not really worth it as you can create other problems.
1 year 7 months ago - 1 year 7 months ago #247081 by Old Magnet
If the previous owner plugged the drain from the cavity between the transfer pump seals then seals are most likely your problem. They've gone and negated this safety feature.
1971 is correct and you would have one of the  D333c's before the change at 96J3588 to the 3306.
1 year 7 months ago #247083 by Quadrajet2000
Thank you everyone for the input.
At this point I'm committed to rebuilding this mess. Hopefully my engine bearings aren't destroyed by all of this but I'm wondering if I just need a complete overhaul. My oil pressure was good but it started spraying an fuel/oil mix out of the crankcase breather pipe under engine load. I shut it down and realized the oil was more fuel than oil.
1 year 7 months ago #247094 by trainzkid88
you might be lucky a caught it in time. maybe all she needs is a set of rings gaskets and bearings without having to regrind the bearing journals. isnt that the point of that weep hole if it leaks there time to rekit the transfer pump. same with water pumps on most engines if they leak from the weep hole time for a rebuilt pump
Time to create page: 0.155 seconds
