D4D with "water in the oil"
Thank you received: 45
1 year 8 months ago #246090
by LangdonStevenson
I was browsing dozers for sale and saw a D4D going cheap with the ominous words: has water in the oil on the ad. Does anyone feel like speculating on possible causes and their seriousness?
I'm thinking: blown head gasket, or cracked head, or cracked engine block, with the first being minor, the second being serious, and the third being major.
Thoughts?
212 grader, 301.5CR excavator, 226B3 skid steer (and fingers crossed a D6 8U coming my way soon!)
Thank you received: 121
1 year 8 months ago #246091
by PhilC
Could also be the seals on the bottom of the sleeves. Maybe an internal leak in a heat exchanger although that usually ends up with oil in the water.
1 year 8 months ago #246093
by LangdonStevenson
PhilC - ok that's interesting to know (and would go on the "major" list).
Thank you received: 502
1 year 8 months ago #246095
by ctsnowfighter
RED Flags - How Much Water is in the Oil? How Much has it run with water in the oil? Any bubbles in radiator?
Bearings and Water are not very compatible - you might be looking at a Major Overhaul anyway you go,
As with anything - you should fully access the condition of the entire machine - Sometimes CHEAP means, I want more than junk price and rid myself of a headache!
CTS
1 year 8 months ago #246121
by LangdonStevenson
CTS - I don't know the answers to any of those questions sorry - I've only seen the brief description in the add and haven't talked to the owner about it. I think that you are right to say that you would have to assume that it would require a major overhaul of the engine (as well as anything else it might require).
Thank you received: 789
1 year 8 months ago #246129
a family friend had a issue with her benz and water getting to the oil, we added a bottle of nulon engine sealer and it fixed it so some times they are a easy fix. yes many mechanic in a bottle remedies are just band-aid solutions.
really untill you see the machine you cant tell anything. it might be simple it might be a full rebuild.
1 year 8 months ago #246130
by LangdonStevenson
Trainzkid88 - true, from what has been said though, I have a feeling that assuming it will be a full rebuild is the safe assumption.
