Pinion shaft bearing 933f
1 year 9 months ago #245827 by Arkie
I'm close to reinstalling the pinion gear assembly in my 933f.  At some point I'll need to press the left bearing on with the shaft,hub, and gear assembled and back in the machine.  The manual shows it being pressed with a specific caterpillar press that I don't have access to. I'm hoping has crossed this bridge and can offer input on doing it without that press. The shaft has the right bearing pressed on and is in the freezer now. Thanks for any insight.
1 year 9 months ago #245829 by neil
Replied by neil on topic Pinion shaft bearing 933f
I'm not familiar with that specific scenario but for my D2, there are various special Cat tools required for pressing that I don't have, so I had my machinist make up various adaptors etc. for a generic hollow ram that I can push and pull with up to 20 tons (they make them larger as well). That could be an option for you. For you left bearing, you could take a shot at putting in in hot oil up to 250 degrees and then quickly getting it on the shaft, but you do run the risk of it not making it all the way. Then you would need sometihng for sure
1 year 9 months ago #245830 by Arkie
Replied by Arkie on topic Pinion shaft bearing 933f
Yep. I'd thought of heating the bearing too. It took hours to pull the old one off using a torch and a port-a-power. Hadn't thought of a hollow ram. The only thing I can think to push the bearing with the port-a-power is the axle nut that holds the clutch pack. I'm not sure it will handle being subjected to the pressure it'll take to press the bearing though. Neil, thank you for responding!
1 year 9 months ago - 1 year 9 months ago #245837 by trainzkid88
if you go the heat in oil trick you want to shrink the shaft in the freezer first or even a bucket of iced water. this give more work time. there is also shrinking with liquid nitrogen.
the idea of shrinking the shaft too is you get a extra few thou clearance and that can make all the difference between slides into place or having to drive it.
Last edit: 1 year 9 months ago by trainzkid88.
1 year 9 months ago #245839 by Fat Dan
Replied by Fat Dan on topic Pinion shaft bearing 933f
I have the luck to have a tool & equipment rental store in the next town. I have rented other tools and equipment from them over the years. It would be worth a call around to see if they have one.
ACMOC Member
1 year 9 months ago #245843 by neil
If you heat the bearing, the nut will hold it. I got a thicker nut just for this purpose that engaged with more threads and I had no problem pushing my bearings on. I think with one of them I actually just tapped it on with hammer and punch after "seeing how far it went on"
1 year 9 months ago #245852 by Arkie
I'm to point of not worrying how big the bear is , I just need to tackle it!
This bearing was a nightmare to pull and hopefully this old machine will show some kindness and let me put it back together. Thanks to everyone who have taken the time to respond!
Arkie
Time to create page: 0.434 seconds
