d-4 7u No. 44 hydraulic control
1 year 9 months ago #245631 by cfbromm
Need some advice, understanding control plunger and spring. The # of unit is 8f1123 Hydraulic cylinder group right hand.
Are parts readily available?
I am trying to sent pictures, no luck yet.
Thanks for responding.
1 year 9 months ago #245633 by PNW.Hillbilly
All the o-rings are easy to find, if your plunger is worn that might be a problem. Are you having a problem knowing the order to put the bolt, springs, and washers back together?
1 year 9 months ago - 1 year 9 months ago #245636 by Fat Dan
I recently uploaded to the library " Servicemen's Reference Book Caterpillar Hydraulic Controls and Equipment "
Covers a lot on No. 44 Hyd Controls
No. 46 Hyd Controls
Hyd cyl for bulldozers and implements
No. 40 Hyd Controls scrapers hyd cyl and valves
Flow diagrams
Flow diagrams for the No. 41 Hyd Controls
Hope it helps
ACMOC Member
Last edit: 1 year 9 months ago by Fat Dan.
The following user(s) said Thank You: PNW.Hillbilly, cfbromm
1 year 9 months ago #245651 by cfbromm
No, PNW.HILLBILLY. Thanks for information on the o rings. And Thanks for You Tube videos.
So far, I just pull the plunger out of the cylinder. Just study that relief valve. I have no spring action in relief valve.
Thanks, Fat Dan for your information. I'll checking that out.
Time to create page: 0.143 seconds
