looking for Track link pins
Thank you received: 124
1 year 9 months ago - 1 year 9 months ago #245571
by side-seat
Make some out of 4140HT
As much use you'll give the machine driving around shows, I doubt you'd wear them out.
May take a bit of work though.
Fat Dan
Thank you received: 90
1 year 9 months ago #245585
by kittyman1
your suggestion doesn't make sense for someone that wants a simple track pin...
- if it's low use almost anything will work...
Thank you received: 999
Thank you received: 789
1 year 9 months ago - 1 year 9 months ago #245606
if you can get hold of all the measurements no reason why a good machinist cant turn some up for you out of high grade bar. it wont be cheap though. if you have part number see if you can find the NSN national stock number via google search with that you can find what other machines used that part and you might find joy that way.
if you can get the blueprint drawing of the part it will make life much easier for the machinist.
Fat Dan
Thank you received: 30
1 year 9 months ago #245638
by Shaban1983
Best to get original ones, they were hardened.
If you get one turned, you will need to do the hardening as well, unless its only used for show purposes.
Fat Dan
1 year 9 months ago #245645
use the right steel and it can be case hardened or induction hardened a good engineering shop should be able to do this for you. like i said it wont be cheap. you could try ITR they might have something that will fit. you'll need the measurements though
Thank you received: 663
1 year 9 months ago #245652
Would anyone happen to know what depth the pins are likely hardened to, and whether it would be the same depth on the ends of the pins?
1 year 9 months ago #245663
by side-seat
Neil, A quick look at my drawings of the PT10 & PV15 says Rockwell C60-65 to a depth of .090" - .120"
This is the same on the roller shafts and Idler shafts.
