Removing screws on D4C 40A
1 year 9 months ago #245386 by Fizfat
Im trying to remove the transmission cover and am needing to remove the bellcrank pin screws, is there a good way to remove them without tearing them up? Looks like someones already tried with a chisel. Iv tried a large screwdriver and they are on there good
1 year 9 months ago - 1 year 9 months ago #245389 by D4Jim
Replied by D4Jim on topic Removing screws on D4C 40A
Put penetrating oil like Kroil anywhere you can reach and try a hand impact screwdriver. It works better than a regular impact wrench as when you hit the end with a hammer it automatically keeps the driver fully engaged with the screw. Less likely to tear up the screw slot.
duckduckgo.com/?q=impact+screwdriver&t=n...ch%3Fv%3Di0JFWBntAVA
ACMOC Member 27 years
D47U 1950 #10164
Cat 112 1949 #3U1457
Cat 40 Scraper #1W-5494
Last edit: 1 year 9 months ago by D4Jim.
1 year 9 months ago #245395 by trainzkid88
as jim said. proper penetrating oil and a impact driver. the secret is set the thing to turn the right way and try and undo them holding that force as you strike it with the hammer and give it a good hit not a love tap.
1 year 9 months ago #245397 by Fizfat
Replied by Fizfat on topic Removing screws on D4C 40A
Will do i appreciate it, That was going to be my next step but i wanted to make sure
1 year 9 months ago #245400 by Rome K/G
Replied by Rome K/G on topic Removing screws on D4C 40A
Check if there is a nut underneath the case or bracket.
The following user(s) said Thank You: gary in CA
Time to create page: 0.153 seconds
