Grease tube for 933f
Thank you received: 6
1 year 11 months ago #245325
by Arkie
I'm close to having all the parts to put my machine back together. I'm needing grease tube 1h6752 for the steering clutch controls. Both were missing when i disassembled.. I've located the bolt but the tube is another story. Internet shows it fits several machines bur no luck finding them. Any ideas where to locate them will sure be appreciated. Thanks
Fat Dan
Thank you received: 1000
Thank you received: 810
1 year 11 months ago #245335
by Arkie
Thanks for responding. I only found one site online and they were out of stock. I knew it looked like a banjo fitting but since it is a grease fitting, I thought it was a specialty fitting. Thanks again.
Fat Dan
1 year 11 months ago #245354
originally it might have been a bit of copper tube on that banjo fitting rather than rubber hose check the other side and see what it looks like, easily made up if you can solder.
Fat Dan
Thank you received: 279
1 year 11 months ago #245363
by rax200
Hi Arkie,
I did these on my D4 steering clutches, as my hoses where falling apart too, so I took them to a hydraulic hose repair and they made up new hoses crimped to my fittings.
Trainkid88 they have tobe flexible as they mount on moving parts on the steering clutch release bearings,
Regards
Daryl
1937 RD4 4G4368
1940 D4 7J3717
1942 D4 7J9915SP
1942 R4 6G2550SP
1944 D4 2T6584SP
1945 D4 2T8978SP
1946 D4 5T6271
1956 D4 7U37855
1954 DH226 S/N 89 Howard Tug
1 year 11 months ago - 1 year 11 months ago #245365
i didnt know they were hose to be flexible. yes get proper grease hose. is yours grease lubed ours is oiled. get new copper or fibre washers too.
Fat Dan
1 year 11 months ago #245407
by Arkie
I'm fairly certain they're grease fittings. Only one side was there and the parts are in the photo. I hadn't thought of a banjo fitting but it makes sense. The bearing is in bad shape and I'm replacing it, but there's no way I'm in this deep and not have the ability to lubricant the replacement bearing. Thanks for responding. The manual and parts book are good, but hearing from people that have been there helps a lot too!
Fat Dan
