D6 9U oil blowing out of exhaust
1 year 9 months ago #245277 by Jsully50
I have a 1950 D69U that I’m working on. When I run it oil blows out the exhaust. Any thoughts on what it could be?? Thank you in advance!!
1 year 9 months ago #245281 by dpendzic
Get it hot and run it hard for a day
D2, D3, D4, D6, 941B, Cat 15
Hancock Ma and Moriches NY
1 year 9 months ago - 1 year 9 months ago #245282 by Fat Dan
Yeah a good four to eight hour shift at full load would help to clean the 'Slobbering' out. Keep an eye on the temp ... if it don't want to come up to temp check your thermostats are closing all the way. That carbon infused oil I removed with oven cleaner, lye, and drain cleaner and let it set over night at 25ish°F. Then pressure wash with hot water.
ACMOC Member
Last edit: 1 year 9 months ago by Fat Dan. Reason: Clarity
1 year 9 months ago #245283 by Fat Dan
These old rigs were made to run. Letting them set for long periods of time is not all that good on them. Things inside get tarnished like the cylinder walls and the rings will most likely lose their seat. One reason for it slobbering is the rings my need reseated. That is why once you get it up to temp you need to reseat the rings by running the puppy water out of it.
ACMOC Member
1 year 9 months ago #245287 by Jsully50
Awesome thank you all for the info!!
1 year 9 months ago #245332 by trainzkid88
worn valves guides can also cause that but most common cause is stuck rings or glazed bores from running at idle or low load too much. diesels need to be worked. dont ring their neck but work em.
whats the oil like? i suggest a oil and filter change and work it. push some dirt around or find something heavy to drag around the yard.
to clean that crud off the exhuast use a product called shock treatment its made by applied chemicals and is part of thier chemtech range of products. it works very well its cuastic soda based so it will strip the fats from skin and burn you so wear gloves.
a hot water pressure cleaner is the bees knees for removing grease and grime. most equipment hire places have them.
1 year 9 months ago #245341 by Jsully50
The oil is sticky black. And thank you for the info sir
1 year 9 months ago #245344 by steeltracs
Put cardboard in front of radiator and bring it up to temp, then work it but don’ let it over heat
1 year 9 months ago #245357 by trainzkid88
what i meant was the oil in the sump. check its condition. but oil and filters are cheap, parts are not so its fairly cheap to simply change it and then you know its got good oil in it.
my thinking when you buy a old machine is check all the fluids if they look okay, get it to start so it runs and moves, no bad noises then good, give it a oil change fresh oil is cheap insurance.
1 year 9 months ago #245387 by Fat Dan
trainzkid88 ....⬅️ yeah what he said.
Thanks trainzkid88 for helping me explain that, it's coming back slow but it's coming back 👍😉
ACMOC Member
Time to create page: 0.144 seconds
