D6 9U oil blowing out of exhaust
Showing 1 to 10 of 13 results
Jsully50
Send a private message to Jsully50
I have a 1950 D69U that I’m working on. When I run it oil blows out the exhaust. Any thoughts on what it could be?? Thank you in advance!!
Tue, Feb 7, 2023 4:21 AM
Get it hot and run it hard for a day
Tue, Feb 7, 2023 4:57 AM
Fat Dan
Yeah a good four to eight hour shift at full load would help to clean the 'Slobbering' out. Keep an eye on the temp ... if it don't want to come up to temp check your thermostats are closing all the way. That carbon infused oil I removed with oven cleaner, lye, and drain cleaner and let it set over night at 25ish°F. Then pressure wash with hot water.
 [attachment=70987]KI5684ment.jpg[/attachment]
Tue, Feb 7, 2023 5:17 AM
Fat Dan
Reply to Fat Dan:
These old rigs were made to run. Letting them set for long periods of time is not all that good on them. Things inside get tarnished like the cylinder walls and the rings will most likely lose their seat. One reason for it slobbering is the rings my need reseated. That is why once you get it up to temp you need to reseat the rings by running the puppy water out of it.
Tue, Feb 7, 2023 5:37 AM
Jsully50
Reply to Fat Dan:
Awesome thank you all for the info!!
Tue, Feb 7, 2023 7:06 AM
Thank you received: 34
Reply to Jsully50:
worn valves guides can also cause that but most common cause is stuck rings or glazed bores from running at idle or low load too much. diesels need to be worked. dont ring their neck but work em.
whats the oil like? i suggest a oil and filter change and work it. push some dirt around or find something heavy to drag around the yard.
to clean that crud off the exhuast use a product called shock treatment its made by applied chemicals and is part of thier chemtech range of products. it works very well its cuastic soda based so it will strip the fats from skin and burn you so wear gloves.
a hot water pressure cleaner is the bees knees for removing grease and grime. most equipment hire places have them.
Wed, Feb 8, 2023 4:32 PM
Jsully50
Reply to trainzkid88:
The oil is sticky black. And thank you for the info sir
Thu, Feb 9, 2023 12:58 AM
steeltracs
Thank you received: 5
Reply to Jsully50:
Put cardboard in front of radiator and bring it up to temp, then work it but don’ let it over heat
Thu, Feb 9, 2023 2:02 AM
Reply to steeltracs:
what i meant was the oil in the sump. check its condition. but oil and filters are cheap, parts are not so its fairly cheap to simply change it and then you know its got good oil in it.
my thinking when you buy a old machine is check all the fluids if they look okay, get it to start so it runs and moves, no bad noises then good, give it a oil change fresh oil is cheap insurance.
Thu, Feb 9, 2023 11:36 AM
Fat Dan
trainzkid88 ....⬅️ yeah what he said.
Thanks trainzkid88 for helping me explain that, it's coming back slow but it's coming back 👍😉
Fri, Feb 10, 2023 11:16 AM
74A6C
Send a private message to 74A6C
Reply to Fat Dan:
IIRC, Dan, didn't one of your graders put up a slobbery fight during your thermostat trouble? Seems like it took a couple of good exercises before you got it cleared up. I'll agree with the previous statements, get it to temp and put a steady load on it after getting it nice and warm and changing the current oil for a fresh service. JSully, how long has the tractor you're working on been sitting?
Tue, Feb 14, 2023 10:42 AM
