RD6/D6 2H water pump help
2 years 2 days ago #245065 by Tristan
Hello everyone,
I have a 1940 D6 2H it leaking coolant from the packing nut on the water pump. How do I go about changing the packing?
Thank you for an advice.
Tristan
1940 D6 2H
1945 D4 5T
1947 D2 5J
1938 D3 5J
2 years 2 days ago - 2 years 2 days ago #245067 by Rome K/G
Replied by Rome K/G on topic RD6/D6 2H water pump help
How "bad" is the leak? It is supposed to drip so many drops a minute to lube the packing and keep the shaft from overheating.
Last edit: 2 years 2 days ago by Rome K/G.
2 years 2 days ago #245069 by Tristan
Replied by Tristan on topic RD6/D6 2H water pump help
It's a steady stream when running from the pony motor side.
Tristan
1940 D6 2H
1945 D4 5T
1947 D2 5J
1938 D3 5J
2 years 1 day ago - 2 years 23 hours ago #245084 by trainzkid88
most irrigation rural supplies places will have gland packing and good industrial suppliers will have it too.
is there any adjustment left on the gland nut? you remove the nut wipe a bit of marine grease in there and do it up again, if not adjustment left it needs new packing.
if you replace the packing lube the threads on the gland nut with a little graphite grease or nickle anti sieze makes life easier next time.
use a hook and pick tool to remove the old packing
Last edit: 2 years 23 hours ago by trainzkid88. Reason: more info
2 years 1 day ago #245090 by juiceman
Replied by juiceman on topic RD6/D6 2H water pump help
Dealers carried the packing for a 3T D7 at one time; a neighbor substituted it for the packing on his 30. I don't know what the shaft diameters are, perhaps it would work for your RD6 as well; as others suggested, pump packing material should be readily available from an irrigation pump company. JM
2 years 12 hours ago #245116 by 8C 361
Replied by 8C 361 on topic RD6/D6 2H water pump help
On my 1H D8 gland nut was stuck and been leaking for years. With a little heat it came free and I cleaned up the threads, Packing is non specific. 3/8" square I think, cut to length, tighten a bit. Hasn't leaked in years.
1 year 11 months ago #245311 by Dieselholic92
Caterpillar still supplies packing for water pumps. At least my dealership was still able to get it back in 2014 or 2015
Thirty Five gas, D4 5T, D6 2H, D6 9U, D7 17A, No. 12 70D, 12E, 12E, 922B, 922B
www.dandgexcavating.com
1 year 11 months ago - 1 year 11 months ago #245316 by rax200
Replied by rax200 on topic RD6/D6 2H water pump help
Packing 1b8088 still avaliable at Cat.
Daryl
1937 RD4 4G4368
1940 D4 7J3717
1942 D4 7J9915SP
1942 R4 6G2550SP
1944 D4 2T6584SP
1945 D4 2T8978SP
1946 D4 5T6271
1956 D4 7U37855
1954 DH226 S/N 89 Howard Tug
Last edit: 1 year 11 months ago by rax200. Reason: Add part number
