D6C governor control
1 year 10 months ago #244912 by greengiant
 does anybody have a D6C shop manual that shows how to assemble the governor control? I have a parts manual but the diagram is clear as mud.Mine was frozen solid. I got the gadget on the end apart but the innards fell out on the bench. I can tell where 2 springs go but not where the 3rd goes and not how the rollers fit in.I also don't understand the function  of the gadget or what might be the result of just leaving the rollers and springs out.Thanks!
1 year 10 months ago #244922 by seiscat
Replied by seiscat on topic D6C governor control
What is the serial number of your D6C? They were produced from 1963 to 1976 so there are some changes.
Craig
1 year 9 months ago - 1 year 9 months ago #244923 by Rome K/G
Replied by Rome K/G on topic D6C governor control
Note there are two different springs from the three. The smaller spring fits in the notch.
Last edit: 1 year 9 months ago by Rome K/G.
1 year 9 months ago #244924 by greengiant
Replied by greengiant on topic D6C governor control
Great, thanks! I think View A-A solves the puzzle. I did notice the smaller spring and notch but still don't see what purpose they serve. A strange device and probably never intended to be taken apart but it was frozen solid, couldn't move the governor lever at all.. cleaned it up and it's good now. just need to get it together and back on the machine. actually quite enjoyable altho it took some contorting and bruised hands to get it out of its hidey place..
The following user(s) said Thank You: Rome K/G
1 year 9 months ago #244925 by Old Magnet
Replied by Old Magnet on topic D6C governor control
From the Service Manual...
The following user(s) said Thank You: Busso20
1 year 9 months ago #244935 by greengiant
thanks Old Magnet, this info is very good. now i see the purpose of the little spring, it's just to make sure the shaft assemblies are aligned. I got the thing reassembled pretty much the way the book recommends except i used a wire to compress the roller springs. sadly, after getting it back together it's still locked up. I had thought the problem was corrosion which I cleaned. so it's something else.. it turns freely without the rollers in place. I'll have another run at it this weekend.
1 year 9 months ago #244941 by 74A6C
Replied by 74A6C on topic D6C governor control
On my 76A series machine, I was having similar issues. New bushings in the bellcrank assembly and the throttle lever made the greatest improvement. Mine doesn't have a decelerator pedal so the hand lever has had all the use and it shows. I gave all the shafts and bushings and inside of the governor control a painting of anti-seize whether or not it made much difference remains to be seen. Following the picture using the wooden blocks is a near must for reassembly.
1 year 9 months ago #244942 by 74A6C
Edit: I meant 74A series tractor
1 year 9 months ago #244980 by greengiant
took it apart, examined all the pieces, they all look good, put it  back together and it's locked again. the mystery is that one day it was working and the next day it was locked. what is the purpose of this Rube Goldberg device anyway? what would happen if I bypassed it altogether?
1 year 9 months ago #244981 by Old Magnet
They are famous for function problems, more often don't hold than lock up. Conditions have to be near perfect for them to work. No worn ramps or rollers, no grease, just use light oil. Without it working there is nothing to hold throttle position.
Time to create page: 0.208 seconds
