D6C governor control
Showing 1 to 10 of 15 results
greengiant
Send a private message to greengiant
 does anybody have a D6C shop manual that shows how to assemble the governor control? I have a parts manual but the diagram is clear as mud.Mine was frozen solid. I got the gadget on the end apart but the innards fell out on the bench. I can tell where 2 springs go but not where the 3rd goes and not how the rollers fit in.I also don't understand the function  of the gadget or what might be the result of just leaving the rollers and springs out.Thanks!
  [attachment=70864]DSC00917.JPG[/attachment][attachment=70865]DSC00916.JPG[/attachment][attachment=70866]DSC00918.JPG[/attachment]
Wed, Jan 25, 2023 10:22 AM
seiscat
What is the serial number of your D6C? They were produced from 1963 to 1976 so there are some changes.
Craig
Wed, Jan 25, 2023 9:41 PM
Note there are two different springs from the three. The smaller spring fits in the notch.
[attachment=70869]Throttle Control 001.jpg[/attachment]
Wed, Jan 25, 2023 11:57 PM
greengiant
Great, thanks! I think View A-A solves the puzzle. I did notice the smaller spring and notch but still don't see what purpose they serve. A strange device and probably never intended to be taken apart but it was frozen solid, couldn't move the governor lever at all.. cleaned it up and it's good now. just need to get it together and back on the machine. actually quite enjoyable altho it took some contorting and bruised hands to get it out of its hidey place..
Thu, Jan 26, 2023 12:27 AM
Thank you received: 14
Reply to greengiant:
From the Service Manual...
 [attachment=70870]Governor-Control-#1.jpg[/attachment]
 [attachment=70871]Governor-Control-#2.jpg[/attachment]
Thu, Jan 26, 2023 1:15 AM
greengiant
thanks Old Magnet, this info is very good. now i see the purpose of the little spring, it's just to make sure the shaft assemblies are aligned. I got the thing reassembled pretty much the way the book recommends except i used a wire to compress the roller springs. sadly, after getting it back together it's still locked up. I had thought the problem was corrosion which I cleaned. so it's something else.. it turns freely without the rollers in place. I'll have another run at it this weekend.
Thu, Jan 26, 2023 7:23 AM
74A6C
Send a private message to 74A6C
On my 76A series machine, I was having similar issues. New bushings in the bellcrank assembly and the throttle lever made the greatest improvement. Mine doesn't have a decelerator pedal so the hand lever has had all the use and it shows. I gave all the shafts and bushings and inside of the governor control a painting of anti-seize whether or not it made much difference remains to be seen. Following the picture using the wooden blocks is a near must for reassembly.
Thu, Jan 26, 2023 10:29 AM
74A6C
Reply to 74A6C:
Edit: I meant 74A series tractor
Thu, Jan 26, 2023 10:31 AM
greengiant
Reply to 74A6C:
took it apart, examined all the pieces, they all look good, put it  back together and it's locked again. the mystery is that one day it was working and the next day it was locked. what is the purpose of this Rube Goldberg device anyway? what would happen if I bypassed it altogether?
Fri, Jan 27, 2023 8:25 AM
They are famous for function problems, more often don't hold than lock up. Conditions have to be near perfect for them to work. No worn ramps or rollers, no grease, just use light oil. Without it working there is nothing to hold throttle position.
Fri, Jan 27, 2023 8:37 AM
greengiant
so that's what it's for! thanks! that gives me incentive to keep working on it or find a replacement.
Fri, Jan 27, 2023 12:38 PM
CAFES 2025 TULARE, CALIFORNIA
| Tulare, California
| 34 Henty Hwy, Warracknabeal
Veerkamp Open House 2025
| Placerville, CA
Stradsett Park Vintage Rally
