add a water heater to d-4
1 year 10 months ago #244164 by cfbromm
I have a D-4 ( # 24270} and want to a water heater. I found one opening on the lower radiator hose. Looking for a place for returning to the radiator system.
1 year 10 months ago #244202 by rax200
Replied by rax200 on topic add a water heater to d-4
Hi cfbromm,
The other outlet or inlet is the drain on the engine block
Regards
Daryl
1937 RD4 4G4368
1940 D4 7J3717
1942 D4 7J9915SP
1942 R4 6G2550SP
1944 D4 2T6584SP
1945 D4 2T8978SP
1946 D4 5T6271
1956 D4 7U37855
1954 DH226 S/N 89 Howard Tug
The following user(s) said Thank You: cfbromm
1 year 10 months ago #244210 by kracked1
Replied by kracked1 on topic add a water heater to d-4
The block drain makes a good inlet for your tank heater. On my 7U there is a small 2 bolt block off plate in the thermostat housing. It is on the same side as the fuel filter housing. That plate can be removed and a pipe bung welded in. That makes a good return as it is at the head level and will circulate through most of the whole engine. Make sure you follow directions on mounting the heater.
Time to create page: 0.127 seconds
