Went to look at a D-2 Cat.
1 year 11 months ago - 1 year 11 months ago #243134 by Dandy Dave
A D-2 Cat was on FB Market place and advertized as a 1955. The serial is 7XXX and it is a 1951. It is near Brookfield, NY. the fellow selling it had left water in the engine one winter so it has water in the engine oil. I found the pins and bushings worn pretty bad. At least 75 % or more. I walked away. Just though I may save some of you a trip if your looking at it. I would have bought it for the undercarrige if it was in better shape.
1940 Cat 12 Grader 6M17
1956 Cat D2-5U
1956 Cat D6- 9U 23721
Copake, NY.
Last edit: 1 year 11 months ago by Dandy Dave.
The following user(s) said Thank You: crookedwrench, Fat Dan
1 year 11 months ago #243135 by neil
Replied by neil on topic Went to look at a D-2 Cat.
Hi Dave, I wish it was a 55 because I'm part-time looking for replacement track frames for my '53 5U13753, which has the longer track frames. A 7xxx will be the shorter frames unfortunately. Did it have track frame covers on it by any chance?
1 year 11 months ago - 1 year 11 months ago #243165 by Dandy Dave
Not the front covers. Only the ones over the springs. It also had a crude farm built blade on it. He said it steered both ways when he had it running a few years ago before the engine froze. I did not bother with pulling the steering clutch levers too see if there was any resistance, or trying the brakes just to see if there was any meat on them. It did have a lot of meat on the grousers, But a hole cut in every one like it was used to push snow at one time. It also had a PTO. It did not have the big cover for the master clutch like the later D2's. The pins and bushings were never turned but they are well beyond that point now. Serial numbers did match.
1956 Cat D2-5U
Copake, NY.
1 year 11 months ago #243166 by Dandy Dave
1956 Cat D2-5U
Copake, NY.
1 year 11 months ago #243364 by Dandy Dave
Last I looked this tractor has been sold.
1956 Cat D2-5U
Copake, NY.
Time to create page: 0.149 seconds
