Stuck D2 5U Steering clutches
Thank you received: 76
1 year 11 months ago #243117
by deereskinner
Purchased a D2 5U #8891 last summer with stuck steering clutches, tried all tricks that everyone suggested to get them unstuck and just got caught up enough to get in shop and have one side tore down and have clutch pack on the bench to release springs and pry apart the discs. My question is if my discs are not usable where can I get replacements or parts, are they even available?
Thank you received: 663
1 year 11 months ago #243119
Get your replacement disks from General Gear. I picked up disks (both sorts), both hubs, new brake bands, and a couple of other items from GG - all fit correctly and work as expected
1 year 11 months ago #243120
by deereskinner
Thanks so much and I could even go pick it up it up since its within 300 miles of home, heard of a place in Boise but couldn't get a name and you've answered my prayers
1 year 11 months ago #243130
by ol Grump
General Gear is a few miles east of Boise, just off I 84. Can't remember the exit but you can see it from the freeway. John is a good guy to deal with.
Thank you received: 71
1 year 11 months ago #243133
by Dandy Dave
I stopped by General Gear a number of years ago when I was out west and purchased some parts. It is worth a look if you have the time and your close. I also found them to be good folks.
1940 Cat 12 Grader 6M17
1956 Cat D2-5U
1956 Cat D6- 9U 23721
Copake, NY.
Thank you received: 502
1 year 11 months ago #243144
by ctsnowfighter
Sometimes the discs are so full of rust they will compress the springs so tightly you can not remove the keepers! That may require replacement of the entire assembly.
While you have it torn down and the clutches apart -- make sure you look at the "splines" inside the drum - they can become so worn it is difficult to to remove the drum and also affects the clutch operation.
Years ago, a "fix" for steering clutches that were worn - add another disk to make up the thickness - it often got one by for a period of time -
This was not an uncommon practice, especially as Cat orphaned many of the older machines, no longer were parts available.
Best of Luck.
cts
1 year 11 months ago #243146
Yes, I had to cut my inner hub off the shaft as the 20t ram wouldn't move it. All the plates, keepers, springs, etc. were all trash. It's all brand new now, both sides, and works like power steering
Time to create page: 0.153 seconds
