Caterpillar D2 wet stacking/exhaust slobber
2 years 19 hours ago #243026 by trainzkid88
if the oil smells of fuel or is thin dont run it. fix the pump and give it a oil change. thinned out oil will destroy the bearings due to poor lubrication.
2 years 16 hours ago #243028 by kracked1
I'm going to put a new thermostat in the ol girl today, and I'll flush the cooling system. The bottom hose is always cold, top of the radiator is hot after work, but you can hold your hand on it. Need to get the temperature gauge working, fixed the fuel pressure gauge the other day, needle was gummed up. Hopefully the slobbering goes away. One other question I have, what sort of fuel consumption is normal for a D2? I've only done 3 hours work on a full tank, and it's only got half a tank left. Thanks for the responses
If you can hold your hand on the radiator, it is only 120 degrees or so. That is way to cold to be running a diesel engine at. They will slobber alot at that temp. They need to be close to 180 degrees to have proper combustion.
2 years 16 hours ago #243030 by Deas Plant.
Hi, Fieldchief5U.
Sounds to me like you're leaking more fuel than you're burning, problem being knowing where it is going. Like TK88 said, if it's going into your engine oil, that will KILLL your engine.
If my understanding is 'kee-wrecked', fuel can also get into your engine oil from the injector pump itself. Might be time to have that serviced and replace the seal between the filter tower and the injector pump. Also, make sure that the bleed screw on top of the filter is closing properly. While you have it apart, try blowing back through the drain pipe. If you can get air past the bleed screw while it is closed, it's not closing off properly.
2 years 13 hours ago #243032 by neil
Fieldchief, if you used half a tank in 3 hours, and the tank had been full, then you would have burned say 3 gallons meaning the other 10 or so went elsewhere, such as on the ground as Toby suggested. First check the crankcase and as others recommended, don't run it if the level is higher than when you started and/or the oil smells of diesel. If not, put a catch can under the drip lines and perform a sample run. Check for leaks elsewhere, starting from the tank and working forwards, if the fuel level goes down while it's parked. You want to identify where the fuel is going without risking harming the engine
2 years 11 hours ago #243036 by Markds3
Okay, just joined ACMOC, and here goes. Picked up a very tidy D2, 5U series in exchange for some excavation work, has 8417 hours, and starts and runs beautifully. It hardly smokes at all, maybe a wee bit of blue haze. But the exhaust slobber is terrible, there's wet black oil all inside the exhaust, and spatters everywhere when its working hard. It has decent compression, doesn't take long on the pony to get it to fire up. Top of the radiator is quite hot when running, but the bottom hose is always cold. Does it just need to run hotter, or could it have glazed bores or something? Any advice on how to fix this wet stacking would be great. This is my first Caterpillar, so any advice on where to get filters and parts would also be appreciated.
cheers from New Zealand.
Welcome! I'm a fellow NZ member with a D2 5U which is prone to wet stacking! Where are you based? I'm in Nelson
2 years 4 hours ago #243050 by smokiejoe70
I had a wet stack problem also. I found that I had a blown gasket in the top of my fuel tower.
1 year 11 months ago - 1 year 11 months ago #243053 by Fieldchief5U
The oil seems pretty clean and the level is all good. Smells just like any other used diesel oil I've seen. I might drain a little bit just to see that it's not too runny. On Monday we'll be going into our caterpillar dealer to see if we can get the packing seals for the transfer pump. The end of the drain tube was wet I noticed. It's just a toy of ours, so it can sit around as long as it needs to. I'm located near Dunedin. I think it needs new fuel filters as well. I might just take the fuel tower off and go over it and replace all the seals. Have ordered a new temperature gauge with the right 5/8 thread on the end because the old one was dead. The fuel level stays the same unless it's running. Edit: The packing seal on the pump side of the transfer pump was definitely gone, took it out today. If I can't get these seals from Cat, I'll machine a bush for the shaft and put a modern rubber seal in.
Cheers.
Last edit: 1 year 11 months ago by Fieldchief5U.
