Hour meter housing
2 years 3 days ago #242925 by smokiejoe70
Hello again fellas.  Can anyone tell me if you can replace the glass in my D2s hour meter housing. Everything is good except  the glass.
2 years 3 days ago #242933 by rax200
Replied by rax200 on topic Hour meter housing
Yes you can you will need the following parts below, when you remove the retainer be very careful so you can reuse it as t can't find any on machinery trader you may have to silicon it back in.
2 x 2A5272 seals
1 x 2a5273 glass
1 x 2a5561 retainer
Regards
Daryl
1937 RD4 4G4368
1940 D4 7J3717
1942 D4 7J9915SP
1942 R4 6G2550SP
1944 D4 2T6584SP
1945 D4 2T8978SP
1946 D4 5T6271
1956 D4 7U37855
1954 DH226 S/N 89 Howard Tug
The following user(s) said Thank You: smokiejoe70
2 years 2 days ago #242957 by smokiejoe70
Replied by smokiejoe70 on topic Hour meter housing
Thanks Daryl. Where do I order these parts and is there a video of how to replace the glass?
2 years 2 days ago #242983 by rax200
Hi somokiejoe70,
There is no video on how to do it. The way that I did it on my D4 and should work on the D2 is by dismantling the whole unit if you can,
1, remove the pin that holds on the gear on and remove the gear
2, remove the bearing (housing the supports the shaft) you may have to put this in a vice with soft jaws and twist and lift at the same time.
3, remove shaft,
4, remove nut on the end of the housing and remove counter,
5, use a long small screwdriver and press the glass out from the inside as the retainer is only made of lead or similar material.
6, clean all part EXCEPT counter replace seal 2A5285 in bushing.
7, as for installing new glass it is seal, glass, seal and retainer you may have to use some silicone or rtv to hold the retainer in.
8, lightly grease gear on counter then reassemble all parts in reverse order.
Hope this helps
Regards
Daryl
1937 RD4 4G4368
1940 D4 7J3717
1942 D4 7J9915SP
1942 R4 6G2550SP
1944 D4 2T6584SP
1945 D4 2T8978SP
1946 D4 5T6271
1956 D4 7U37855
The following user(s) said Thank You: kracked1, smokiejoe70
