Ten magneto
2 years 6 days ago - 2 years 6 days ago #242826 by D6Joe
Ten magneto was created by D6Joe
I purchased a Ten cat two month ago on a neighbors estate sale.  I tried to buy it 15 years ago from another neighbor, but it didn’t happen.  This Ten has been within 2 & 1/2 mile of my place for the last 65 years. I has been inside, but has not run in 35 to 40 years.  But it had the yellow paint overhaul way back when.
I have a list of about 2 dozen things to work on. But getting it started this winter is #1.  I need to know if it hold water in the radiator, gas in the tank, etc.
The previous owner had the magneto off, and using my new owners book, I found the timing marks on the front pulley and the block. The mag was 1 revolution off.  After filling the points, I have some spark at the points in the mag, but none at the spark plugs. Weak condenser???  The magneto is an “American” from the tag on it.  What are the point for this mag supposed to be set at? 0.020?   The book says 0.012 for the original mag.
Last edit: 2 years 6 days ago by D6Joe.
2 years 6 days ago #242829 by D6Joe
Replied by D6Joe on topic Ten magneto
Ok, what did I do wrong to end up with small pics?
2 years 6 days ago - 2 years 6 days ago #242831 by rax200
Replied by rax200 on topic Ten magneto
Hi D6joe,With adding points you must press the "insert button" for each picture after this the button should go green.
Hope this helps
Regards
Daryl
1937 RD4 4G4368
1940 D4 7J3717
1942 D4 7J9915SP
1942 R4 6G2550SP
1944 D4 2T6584SP
1945 D4 2T8978SP
1946 D4 5T6271
1956 D4 7U37855
1954 DH226 S/N 89 Howard Tug
Last edit: 2 years 6 days ago by rax200. Reason: Added text
2 years 6 days ago #242832 by 657cat
Replied by 657cat on topic Ten magneto
Pics are fine. They are full size when you click on them.
Twenty L590. Thirty PS8863. RD6 2h1517. #10 Autopatrol 2K701
#11 Autopatrol 6k611. #11 Autopatrol 9F. #12 8T12832. #12 8T19829 #40 Scraper 1w5325. D2 5U4030. D4 7U 22120. D6 9U11633SP.
2 D311 gensets
2 years 6 days ago - 2 years 6 days ago #242834 by Old Magnet
Replied by Old Magnet on topic Ten magneto
That should be an American Bosch MJA4C106 magneto (Cat #4F7494) Point gap is 0.014 - 0.018.
With the magneto dormant that long you will probably need to have the coil remagnatized.
Last edit: 2 years 6 days ago by Old Magnet.
2 years 6 days ago - 2 years 6 days ago #242841 by trainzkid88
Replied by trainzkid88 on topic Ten magneto
here some tips.
clean the mating faces to bare metal then clean with methylated spirit or shellite(white gas / stove fuel) or contact cleaner. warning dont spray inside the mag casing any residue in there can cuase a explosion.
now its spotless take a no2b graphite pencil and rub the mating faces to give a even coating of graphite it must only be on the mating faces any where else clean off with rag dampened metho etc.
check the plug wires for crazing same with the dissy cover cracks leak power. replace leads if cracked. caps can be repaired if not severe.
clean the cap and the rotor button.
change the condensor
clean the plug mating faces too. can be a good idea to fit new plugs just cuase it works nice out the cyl it might not work under compression.
check any kill switch and its wiring for proper operation and any short circuits, cracked insulation etc
remember magnetos rely on the return path via the plug bases, engine block and the magneto case to work.
see if this improves the spark.
if not then the mag  might need rebuilding. if it runs okay leave it alone. mag rebuilds are not cheap.
Last edit: 2 years 6 days ago by trainzkid88.
The following user(s) said Thank You: D6Joe
2 years 5 days ago #242846 by D6Joe
Sounds like a good idea to clean up the mountings.
Time to create page: 0.165 seconds
