Equipment Trailer Opinion
2 years 1 week ago #242736 by Cat Yellow1
I'm looking for an equipment trailer to take my D2 to shows, etc. I'm under the belief that a 10k trailer is too light and need a 12k or 14k. I'll be pulling with a 2016 F150 with the maximum tow package, and can tow up to 12k (with weight distribution hitch). I've been looking at used trailers but it seems like anything halfway decent is priced too high, or it is sold before I see it. After much research, I'm leaning towards a new PJ T6 trailer, which has the 4' stationary and 16' tilt bed. Really rather not put that much into a trailer, which will take most of my hobby budget, but I like the tilt bed for loading and seems like it is easier to find the correct tongue weight with this kind of trailer, and the PJ trailer should hold it's value. I also have a JD SCUT tractor I'd move with it. Thoughts?
2 years 1 week ago #242740 by dpendzic
Replied by dpendzic on topic Equipment Trailer Opinion
I have a 5 ton 16 ft tilt trailer--i have moved my D2 with it but found the stopping distance with my F250 was not ideal
D2, D3, D4, D6, 941B, Cat 15
Hancock Ma and Moriches NY
The following user(s) said Thank You: Cat Yellow1
2 years 1 week ago #242741 by juiceman
Replied by juiceman on topic Equipment Trailer Opinion
My personal opinion says to not even attempt to haul that D2 with your F150. You should be using at least a 3/4 or one ton, say an F450/F550 range. Your trailer would need good electric brakes or hydraulic surge brakes as well. Ability to stop is important with so much weight on. I shopped for a bumper pull Landoll tilt/stationary with winch and was floored. $23,000.00 plus taxes, and most other brands are close behind in pricing. Everything costs a LOT now. Friends have some really nice 5th wheel gooseneck units and they were close to 40K!!! Good luck on your quest for a used trailer, as they do sell fast. JM
The following user(s) said Thank You: Cat Yellow1, Kurt Bangert
2 years 1 week ago #242743 by caterpillar13
how often are you going to move the d2, maybe contact a local tow company and have them move it 1 or 2 times a year, cheaper than a trailer and all of the liability falls on them.
get a little trailer for your tractor.
i used to move my d2 with my 3/4 ton locally / less than 10 miles, but i would not do it now because the traffic has quadrupled, and they are crazier now than ever.....
JUST MY 2 CENTS
2 years 1 week ago #242747 by Kurt Bangert
I run a 14k trailer with a F-350, D2 is fine, a naked, early D-4 is the top limit. Good trailer brakes are a must.
D4 D 78A 6678
D4 6U 1139
RD4 4G223W
D2 5U 1164
JD 350B
JD 420C
2 years 1 week ago #242757 by Cysco
Replied by Cysco on topic Equipment Trailer Opinion
In your truck manual there is a Gross Combination Weight Rating for your truck. That dictates what your max truck and trailer weight would be. Next is your drivers license and most are a standard license with a under 26K rating. Your F150 is not designed for that kind of weight....will it pull it...sure....will it stop it...doubtful. Then there are the tire ratings....the load binder ratings, chain ratings hitch ratings, etc. Lots to consider ......
2 years 1 week ago #242761 by Peter C
Replied by Peter C on topic Equipment Trailer Opinion
I have a 2015 F-150 that I use to tow my Cat 22 weight 6,700#. My pickup with full fuel (36 gallons) and me weighs 5,760#, my trailer weighs 3,000#. That puts me at 15,460# going down the road not counting weight of hitch and tie down chains. Like Cysco said, your truck manual shows you the maximum gross weight of your towing vehicle and load. Mine is16,900#.
Another thing to consider. If you want to mount a winch to your trailer, consider getting a full tilt. Just my opinion.
Hope that helps you decide. Oh, by the way, don't expect to stop on a dime even with good trailer brakes!!
Pete
2 years 1 week ago #242764 by rustrunner
3/4 ton and 16,000# trailer - you will want to haul more than the d2. Truck then rated at 10,000# and trailer at 16,000# legal with no cdl. I run F250 6.7 with 21,000# tilt trailer rated at 16,000#. Legal load is about 12,000# +-. depending the number of people tagging along.. Just hauled D2 TRAXCAVATOR with Hyster winch over smoky mountains, never slowed down.
2 years 1 week ago #242768 by Cat Yellow1
Great input everyone. Thanks. JM, you are correct on trailer prices, they are crazy right now.
2 years 1 week ago #242780 by 43gpw
Replied by 43gpw on topic Equipment Trailer Opinion
I use a local rock yard to have my D4 7U moved. close to14000#. Move is about 90 miles one way, $450.00
so find it better for me to do it this way, less headaches and the cost of having my own truck and trailer,insurance etc. is out of this world now days.
Time to create page: 0.195 seconds
