D8 1H runs again!
2 years 2 weeks ago #242193 by BrianCamling
I got my magneto installed and timed, turned on the fuel to the carb, hit the starter and the pony took right off. So I engaged the pinion, ran the main for a couple minutes to warm things up, threw the compression lever to run and it started puffing smoke, shuddered pretty good and then all of a sudden the main engine took off!  I cut the gas to the pony and had to remember how to engage the clutch on the main to get it to move. But it went forward and backwards and the blade lifted and lowered just fine. I could only run it for a couple minutes because the fan belt broke and I didnt want to take any chances after so long since it ran last. But I am beyond excited to have the old girl running again. If I ever figure out how to post a video I will add it to the post. Thanks everyone for all of the advice over the last few weeks as I have tried to get it to run again. I have a lot of stuff to do yet but this was the biggest hurdle.
2 years 2 weeks ago #242194 by BrianCamling
Replied by BrianCamling on topic D8 1H runs again!
FYI I Have an MP4 file but no idea what to convert it to for a video to add here.If anyone has instructions I would appreciate it. I looked at the pinned article on adding photos but that didnt appear to be the same thing.
2 years 2 weeks ago #242200 by trainzkid88
Replied by trainzkid88 on topic D8 1H runs again!
you can share it via the public folder in g drive or onedrive. all you need to do is post a link to that folder. this can also be a way to share large numbers of photos too.
2 years 2 weeks ago #242208 by rustrunner
Replied by rustrunner on topic D8 1H runs again!
congrats. - ain't no better sound than an old D8
I
2 years 2 weeks ago #242218 by BrianCamling
This might work. here is a link to my video
The following user(s) said Thank You: Deas Plant., gauntjoh, Kurt Bangert, Flathead
2 years 2 weeks ago #242228 by Deas Plant.
Replied by Deas Plant. on topic D8 1H runs again!
Hi, BrianCamling.
Good stuff - thanks for posting.
Please correct if I'm wrong but it appears that somebody has 'transplanted' a late 2U/13A hard nose onto that tractor.
2 years 2 weeks ago #242251 by 8C 361
Replied by 8C 361 on topic D8 1H runs again!
Hi, BrianCamling.
My '39  1H  has the same setup. It has "DOB 1947" marked on the blade with welding bead.  Much better setup than that headache rack.
2 years 2 weeks ago #242252 by BrianCamling
So is the welded date something the plant would have done? I was wondering how to figure out the date for the blade and nose. I can look on mine this weekend and see if it has that
2 years 2 weeks ago #242259 by 8C 361
I assume the date was put on by the shop that did the modification. I have often  wondered what the history of my D8 brfore the blade was put on, farm Cat?
2 years 2 weeks ago #242260 by Deas Plant.
Hi, Brian Camling.
There MAY(??????) be a serial # on the blade but I doubt there will be any indication on the hard nose. The style of hard nose that you have on your 1H first came out on the 2U series from about 1950, about the same time that they changed the transmission from the old 'slide-bar' style to the '5-speed-with-forward-n-reverse' 2-lever arrangement.
The earlier 2Us had the radiator standing alone with braces up from the main frame to support it, allsame the 8R and 1H series. Then, partway through the 2U series, I think around 1947-48, they went to triangular side plates for the braces before they introduced the hard nose in around 1950.
Time to create page: 0.194 seconds
