Startup
2 years 1 month ago #241570 by JohnnyJ
Startup was created by JohnnyJ
Started my 3T after sitting close to 2 years. (I’m slow) End of startup vid shows a cracked fuel line drip from topside injector return line going back to pump. Replaced the fuel galley seals and an area seal and gasket. Dropped off to local Cat distributor (ouch) fuel pump for rebuild. Fuel had began to spill from the wallowed compromised seal (pic) into the crankcase oil. Much .. Thanks to all responders during these types of repairs. Not sure if I can get the exact line that’s leaking. Wondering is it possible or not to use a fuel hose just inside the connections to replace the cracked line.
2 years 1 month ago #241571 by Kurt Bangert
Replied by Kurt Bangert on topic Startup
Congratulations! It's always good to hear about a machine coming back to life.
D4 D 78A 6678
D4 6U 1139
RD4 4G223W
D2 5U 1164
JD 350B
JD 420C
The following user(s) said Thank You: JohnnyJ
2 years 1 month ago #241580 by trainzkid88
Replied by trainzkid88 on topic Startup
no reason you cant use fuel hose as the return isnt under high pressure. you could also solder or braze over the split. if you use hose i would flair the end of the pipe slightly so the hose grips better and is less likely to pull off or leak.
2 years 1 month ago - 2 years 1 month ago #241584 by JohnnyJ
Replied by JohnnyJ on topic Startup
Great info.. so obvious.. Thank you Trainz .. flaring sounds perfect.. sorry the video of actual running and showing fuel leak didn’t paste to this entry.
Last edit: 2 years 1 month ago by JohnnyJ.
2 years 1 month ago #241588 by Kurt Bangert
We're looking forward to the video!
D4 D 78A 6678
D4 6U 1139
RD4 4G223W
D2 5U 1164
JD 350B
JD 420C
2 years 1 month ago #241599 by JohnnyJ
Unable to post the video.. thinking it’s 94.5mb. Maybe too large? Only 80 some seconds .. it’s the 3T running after a 2 year nap.. plus showing a broken fuel injectors return line resulting in a drip.
2 years 1 month ago #241626 by trainzkid88
yes most phones are that high a quality they make very big files. run it through a program called handbrake to compress it.
2 years 1 month ago #241627 by neil
Replied by neil on topic Startup
Put your video on youtube or something similar, make it public, and post the link here.
The following user(s) said Thank You: kracked1, Kurt Bangert
2 years 1 month ago #241629 by Kurt Bangert
I would encourage you to put it on YT as well, then it can be shared here and the collective mind can give you a hand.
D4 D 78A 6678
D4 6U 1139
RD4 4G223W
D2 5U 1164
JD 350B
JD 420C
