D4 7U Part
2 years 1 month ago #241543 by Hank
D4 7U Part was created by Hank
Hi all,
    It has been a long time since I have been on this site, but I need to know what I need so I can replace the part. I looked in the part manuals for the D4 7U but did not see the part I need in the manual.  My D4 is a 7U that was built around October of 1955, the same month and year I came off the line too. The enclosed picture shows the broken part. I do not know what the name of the part is, if you know please tell me. If you have a replacement part like the one I need, I would be more then happy to purchase it. Thank you.
Hank
2 years 1 month ago - 2 years 1 month ago #241545 by D4Jim
Replied by D4Jim on topic D4 7U Part
I think they refer to it as an auxiliary control lever and was an added accessory on most models. There was a handle or knob where the threads were broken off and one could weld or braze a treated rod to the end and fix it. They are sometimes hard to find. Just an extra handy handle to control the injection pump/throttle.
PS:  Go the wanted and for sale forum and ask for the Governor auxiliary control lever.  That is how I found one for my D4.
ACMOC Member 27 years
D47U 1950 #10164
Cat 112 1949 #3U1457
Cat 40 Scraper #1W-5494
Last edit: 2 years 1 month ago by D4Jim.
2 years 1 month ago #241546 by rax200
Replied by rax200 on topic D4 7U Part
Hi Hank,
The level in in the parts book under "fuel pump and governer control" part number is 2h4376 the knob is 7f8092.
Regards
Daryl
1937 RD4 4G4368
1940 D4 7J3717
1942 D4 7J9915SP
1942 R4 6G2550SP
1944 D4 2T6584SP
1945 D4 2T8978SP
1946 D4 5T6271
1956 D4 7U37855
1954 DH226 S/N 89 Howard Tug
2 years 1 month ago - 2 years 1 month ago #241547 by josh
Replied by josh on topic D4 7U Part
Looks to me like there is enough of the lever left, that you could just cut some more threads and put on a new knob.
www.ebay.com/itm/301760939703
Last edit: 2 years 1 month ago by josh.
2 years 1 month ago #241548 by D4Jim
I think Josh has a great idea to cut some more threads and get a knob. You might have to grind a little off to keep the proper OD on the threads but it looks like it wouldn't be much. Good luck.
D47U 1950 #10164
2 years 1 month ago #241554 by juiceman
Replied by juiceman on topic D4 7U Part
I have done as others mentioned. Use a die and thread enough to add the knob;welded a "leg" from a discarded lever/control; cut off the head of a NF bolt and welded on as well.
Yes, because they are a pain to source at times, so you do what works at the time! JM
2 years 1 month ago #241579 by trainzkid88
Replied by trainzkid88 on topic D4 7U Part
i dont know about that knob, but the handles as used on the clutches are still available via the dealer. i would go to the local industrial supply or auto parts joint and get a generic knob and a bit of all thread to suit and weld it to the governor lever.
Time to create page: 0.161 seconds
