D2 Bent Pivot Shaft
2 years 1 month ago #241305 by bpusmc
D2 Bent Pivot Shaft was created by bpusmc
My original pivot shaft is severely worn on one end so I bought a used one. With the replacement (used) one on the bench it appeared to be bent on one end. The other end is relatively straight. Using a level and clamps I got the rough measurements as depicted on the second photo.
Assuming this machine will see occasional light to medium duty ranch work, is 3/16”  an “acceptable” amount of bend. I have read numerous posts on this forum that touch on this subject but no specific details. Some recommendations from the threads I’ve read include:     -use as is     -turn 180 degrees and use
 My current repairs include new idler shafts and bearings and new pivot shaft bearings. Any suggestions would be appreciated. Thanks,Chad
2 years 1 month ago #241306 by Rome K/G
Replied by Rome K/G on topic D2 Bent Pivot Shaft
I would not use that bent shaft, anyway you turn it, it will wear the undercarriage uneven. I had a new shaft made on mine years back.
The following user(s) said Thank You: hfdzl, bpusmc
2 years 1 month ago #241307 by neil
Replied by neil on topic D2 Bent Pivot Shaft
Hi Chad, if you have someone with a 100t press in town, you could take a shot at straightening it. You'd want to go "some" past straight as it will spring back some. It wouldn't cost much to give it a shot, the guy might even do it for free . If it was within a couple of 32nds, and it was me, I'd be ok with that since like you say, you're not using it much. My 5U was well out. The shaft was straight but very worn as were the bushings so as I drove along, the front of the tracks were moving in and out visibly. But given I run it less than 10 hours a year, I wasn't worried. All that said, I have just refurbished the pivot shaft (due home next week) and will be doing the bushings shortly, so basically my advice isn't worth much : )
2 years 1 month ago #241309 by Wombat
Replied by Wombat on topic D2 Bent Pivot Shaft
By the time the 'out' of that shaft gets to the idler the toe in or out will have been magnified, as such will create significant side wear on the rails, if enough may even encourage the track to want to depart its proper course, Yuck, I hate putting tracks back on or even seeing uneven wear patterns.
Wombat
The following user(s) said Thank You: bpusmc
2 years 1 month ago #241311 by d2gary
Replied by d2gary on topic D2 Bent Pivot Shaft
Hey Chad
I have a couple laying around here , I know one is straight but has some wear. Its not to hard to build them up and turn them down by hand. I know you saw what I did and if you have a very limited welding skill its not hard. You're welcome to have the shaft that is worn. I have another one that is still in a tractor not sure of its condition. Neil's suggestions seem good. I had my welder friend straighten some really heavy metal and when you're set up for it not a big deal . Try straightening it if not you can weld up the one I have . Not sure on the shipping but have sent parts to a lot of places .
2 years 1 month ago #241329 by bpusmc
Replied by bpusmc on topic D2 Bent Pivot Shaft
Thanks Neil.  I’ll investigate press possibilities this week.  Glad to hear your pivot shaft is coming back soon.
Chad
2 years 1 month ago #241330 by bpusmc
Scott,
Thanks for your generous offer.  I will let you know how things progress.
Chad
2 years 1 month ago #241337 by Jack
Replied by Jack on topic D2 Bent Pivot Shaft
The first thing you notice when that shaft is worn or sprung is the inability of the tractor to run in a straight line, even on smooth level ground. You will get very tired of pulling on one of the side clutches every 20 yards to straighten it out, and with every pull you will wonder how much damage or wear you are putting on clutches and undercarriage. I say fix it correctly and get your track running centered around the sprocket again. You won't regret it.
Been there on my D2 5J.
Jack
Time to create page: 0.192 seconds
