Trying to find oil filter number
2 years 1 month ago - 2 years 1 month ago #241273 by Peter C
Hi,
I'm trying to find the number of the oil filter cartridge in my R2 6J 1024. The parts book makes no mention of a filter. I am trying to avoid removing the filter and cleaning it to find any number on it. Changing the oil will be one of the last steps before I try to start it after sitting for decades. The R2 sitting for decades, that is!
Any help with this would be appreciated.
Pete
Last edit: 2 years 1 month ago by Peter C.
2 years 1 month ago #241275 by Old Magnet
That looks to be a later filter upgrade available 6J774-up.
Upgrade is a 9F6430 group originally using a 9F6700 full flow filter canister = Cat 1R0659 = Napa 1161 = Wix 51161
2 years 1 month ago - 2 years 1 month ago #241277 by Fat Dan
Cat 10659
Wix 51161
OM you are fast 👍😁
ACMOC Member
Last edit: 2 years 1 month ago by Fat Dan.
2 years 1 month ago #241279 by Rome K/G
I told him that a month ago.......
The following user(s) said Thank You: juiceman, Fat Dan
2 years 1 month ago #241301 by Peter C
Thanks Old Magnet and Fat Dan. The Napa number will make it easy since they are close by and Caterpillar is about an hour away.
Pete
2 years 1 month ago #241317 by Steve A
There are a couple of rubber seals in that canister and on the long hold down bolt I would replace, some leak and you find the old rubber is hard and brittle, available from Cat.
2 years 1 month ago #241320 by Peter C
Steve,
I got a filter from Napa with two seals. I'll be on the lookout when I remove the filter because the seals appear slightly different. Same diameter and height but one appears thinner than the other. No seal for the bolt though. Thanks for the tip.
Pete
Time to create page: 0.153 seconds
