D5 96J steering clutch
2 years 1 month ago #241161 by catsrbest
I have one steering clutch out of my D5. I need to get the 2 cast pieces apart so I can change the throwout bearing. I made a puller and tightened it up and hit the puller with a sledge hammer and nothing... Then I tightened the puller more and broke one of the bolts. Any advice to get it apart... Heat???
2 years 1 month ago #241175 by Ray54
Replied by Ray54 on topic D5 96J steering clutch
The curse of Caterpillar tapered splines. A hydraulic press is almost a must. I have a 40 ton model and it works it to do the 9u D6 clutches. Heat will help, where you using a grade 8 bolt.
2 years 1 month ago #241183 by neil
Replied by neil on topic D5 96J steering clutch
To back what Ray wrote, I have an OTC threaded puller rated for 17t. I also have a hole ram at 20t. The steering hubs for the D2 are supposedly on at about 15t. The OTC puller didn't even look like budging them. The hole ram popped them off just shy of 17t (before the pressure dropped)
Time to create page: 0.148 seconds
