D4 hydraulic question
2 years 1 month ago #241057 by neil
Replied by neil on topic D4 hydraulic question
Todd, in case this is useful to you, we just recently fitted 100R16 hoses to my buddy's D4 Traxcavator, which uses a similar hydraulic control as yours does. The R16 hoses have a shorter radius capability than the R2 and although one spec shows the OD as slightly smaller, we haven't (yet) had any blow off. The clamp halves s are wound down until they touch. Hoses bought from discounthydraulics.com
2 years 1 month ago #241058 by toddsmith23
Replied by toddsmith23 on topic D4 hydraulic question
Thanks! Found both on ebay
2 years 1 month ago #241059 by toddsmith23
Thanks Neil - I already bought the hose at my local hyd shop. However i do need hoses for my Case 320....
Do you happen to know what the working pressure is on the 7V hydraulic system?
2 years 1 month ago #241060 by josh
Replied by josh on topic D4 hydraulic question
Max recommended working pressure 1000 psi, relief valve set at 1200 psi.
2 years 1 month ago - 2 years 1 month ago #241200 by trainzkid88
Replied by trainzkid88 on topic D4 hydraulic question
cat still have the filters. i bought one in the last 2yrs.
you could save that oil if you had a centrifuge but the oil isnt that expensive. you can use the original clamp on code61 fittings with modern 100r2 hose. note the current day cat brand code61 fittings have a heavier flange and need a spacer ring to inter change or the clamping flange milled deeper if you use cat brand fittings with the old flange plates. adapters are also available online to change from code 61 to others such as JIC.
the size is dash 12 a dash is a 16th of a inch note all hose is measured internally
Last edit: 2 years 1 month ago by trainzkid88.
Time to create page: 0.151 seconds
