4G D4 arrangement number question
Thank you received: 15
Thank you received: 121
2 years 3 weeks ago - 2 years 3 weeks ago #241937
by PhilC
You could also look for a D4600 engine as they use the same parts, only 2 more cylinder.
Regards
I thought that too but the parts book that I have for the D6 5R which has the D4600 shows different part numbers for the valves than the ones shown in the D4 4G parts book in the library.
If they are the same then the D4600 valves are still available from Cat.
D4600 valves are 7B9326 inlet and 7B9327 exhaust
Last edit: 2 years 3 weeks ago by
PhilC.
Thank you received: 276
2 years 3 weeks ago #241941
by rax200
Hi Phil and lifeafterourloss,
I just had a look at my parts books fo thr 4g, 2t and d4600 marine book and the 2t use the same as the d4600 so this also means that they will fit the 4g too, as they updated quit a few part numbers.
Regards
Daryl
1937 RD4 4G4368
1940 D4 7J3717
1942 D4 7J9915SP
1942 R4 6G2550SP
1944 D4 2T6584SP
1945 D4 2T8978SP
1946 D4 5T6271
1956 D4 7U37855
1954 DH226 S/N 89 Howard Tug
2 years 3 weeks ago #241942
by LAOL
Thanks everyone, I will see what I can find.
2F 1S 4G (x5) 7J (x2) 5T (x2) 6U 7U (x3)
Thank you received: 789
2 years 3 weeks ago #242114
apparently they did that a lot. used common parts in a engine family to keep cost down. and its a old trick want more power add more cyl. there is no substitute for cubes.
2 years 3 weeks ago #242118
by LAOL
If appears the head had seats installed. Are here Cat seats?
Thank you received: 11
2 years 3 weeks ago #242135
by 657cat
What casting number is your head? I may have one or two. I stripped a few down for parts, may also have a set of good liners as well.
Twenty L590. Thirty PS8863. RD6 2h1517. #10 Autopatrol 2K701
#11 Autopatrol 6k611. #11 Autopatrol 9F. #12 8T12832. #12 8T19829 #40 Scraper 1w5325. D2 5U4030. D4 7U 22120. D6 9U11633SP.
2 D311 gensets
2 years 3 weeks ago #242140
by LAOL
Looks like the part number is 3B9422 and I am guessing the casting number is 0 ULEO. Probably going to need 3 exhaust and 3 intake seats. Liners would be great! Dad and I are determined to get her running. He keeps quoting the German from the 1965 flight of the Phoenix movie. "I have decided to finish this project!"
Thank you received: 125
2 years 2 weeks ago #242182
by Sasquatch
The casting number is the 3B9422, which may or may not match what the part # is for that piece in the manual, since various machining changes along the way or other tweaks to that original casting subsequently changed the part number, although the old casting number remained on the piece because the same raw casting was still being used. The O UL EO is the casting date code, using Cat’s “Numeral Code” formula:
N=0
U=1
M=2
E=3
R=4
A=5
L=6
C=7
O=8
D=9
So the “O UL EO” translates to 8-16-38. You can use this to decide the casting dates of all the major components on the whole tractor, also handy for determining if any major pieces have been replaced in the past 👍
Time to create page: 0.213 seconds
