- Thank you received: 121
D2 and D4's of that era use a clutch that is similar to the steering clutch albeit with only one disk, therefor the pressure plate does not bolt to the flywheel.In fact the only bolt holes in the flywheel are for mounting it to the crankshaftto use a coupler like i described how i would do it is use the clutch pressure plate mounting bolts and dowels bolt a 1/2 inch steel disc to that that has a spigot to go into the pilot bearing bore and a shaft to take the coupler or v-pulley on the out side. the spigot and shaft would be one piece of high grade bright shaft machined to suit recessed and plug welded into the disc. the spigot would be a nice sliding fit into the fly wheel bore so no bearing or bush to vibrate. and all of this nice and close to the flywheel as possible to reduce side loading. i would probably go up a size on the clutch bolts so if 5/16 i would use 3/8 or 7/16. the pressure plate can be the template.
support@acmoc.org
- Chris R
- Jason N
