D2: I Tried to bite off more than she could Chew, bent the Cutting edge plate?
2 years 3 months ago #240619 by G2D2
Dont know if this cutting edge was loose and I missed it or what the deal is, you can see in the pictures half is tight and half is not, I did stall her and took a chunk of dirt out where I could not see the elevation go up real quick so think I bent this edge, looks like it has been done before on the ip side edge.. Anyone know where to get these new bolts and what they are called?  Any tips on blades and cutting edges in general? Had to cut this side bolt off and the main blade metal behind it is really thin!
2 years 3 months ago - 2 years 3 months ago #240621 by bruce oz
  Caterpillar Cutting Edge Bolt, 4F3654 ?
Last edit: 2 years 3 months ago by bruce oz.
The following user(s) said Thank You: G2D2
2 years 3 months ago #240627 by neil
You can get the cutting edges, bolts, and nuts from your Cat dealer. I bought a new set for my D2 blade a couple of years ago
2 years 3 months ago #240632 by D4Jim
Us Redneck farmers call them plow bolts!!
ACMOC Member 27 years
D47U 1950 #10164
Cat 112 1949 #3U1457
Cat 40 Scraper #1W-5494
2 years 3 months ago #240634 by G2D2
 Bruce Oz!  could not figure out why my parts catalog did not have the schematic come to find its just the d2 tractor parts book not the bulldozer !  Thank you for the kind post!
The following user(s) said Thank You: bruce oz
2 years 3 months ago #240635 by G2D2
2 years 3 months ago #240636 by gauntjoh
Hi G2D2,
We have manuals for 2A and 2S (D2) dozers in the members library.
Membership costs from just $44 per annum and supports this website.
2 years 3 months ago #240639 by trainzkid88
the bolts are called plough bolts any good bolt supplier will have them or can get them. any place that sells farm implements will have them too. and smear the with a little anti-sieze when installing makes life easier next time.
2 years 3 months ago #240648 by 74A6C
Plow bolts are what I've always known them to be called, no matter if they're on a CAT tractor, Deere grader or Deere mold board plow. I've had decent luck building up frogs (where your wearable edge bolts) using higher tensile welding rods. 8018 and up, by being careful and lots of use of a 7 inch grinder and a helluva bunch of patience. And always put a full set of new bolts in the particular wear piece you are replacing or turning.
2 years 3 months ago #240649 by 74A6C
As always Mr. Gaunt is correct, a membership is nearly invaluable with it's small fee. Parts book availability is well worth the cost.
The following user(s) said Thank You: Kurt Bangert, G2D2
Time to create page: 0.192 seconds
