Cat 22 Steering & Drive Issues
2 years 5 months ago #240452 by Will_D2
Apologies if this duplicates any previous post, I've looked and couldn't find anything. I'm still a novice when it comes to repairing these old crawlers.
Started doing a bit of work to my someday project, twenty two. Had been parked for a while, not certain for how long, engine starts and runs reasonably well but has issues in the drivetrain. When I first started it wouldn't turn right at all. I followed the operators manual on washing out the steering clutches, in case they'd stuck with years old oil & grease etc. and this seemed to help the situation, regaining steering. However, when I put a load behind the tractor I lost the right steering again. What's worse is that when I pull back on the right steering lever the tractor stops entirely, even without a load.Any ideas why the tractor stops when operating the right steering lever? I've attached photo of tractor and the steering clutch adjustments, if it's anything like D2 looks like they still have some life, could this be overcome by adjustments?
2 years 5 months ago #240453 by gauntjoh
Hello Will, I’m sure others will “chime in”. The reason your tractor stops when pulling back on the right steering clutch is likely to be that the LEFT steering clutch is not working, could be out of adjustment. On a fully operational tractor if you pull back on both steering clutches the tractor will stop as drive is disconnected to both tracks. Interestingly if going down a hill with a load pushing you it’s best to pull the steering clutch opposite to the way you want to turn which allows that side track to speed up, effecting the turn.
2 years 5 months ago - 2 years 5 months ago #240459 by Peter C
This may be your (our) problem. I have a 22 that will not turn to the right when pulling a load but, fortunately, it operates okay for parades. Pete
Last edit: 2 years 5 months ago by Peter C.
2 years 5 months ago #240460 by Ray54
Neighbor had a Cat 22 break one of the drive shafts. I don't remember just where in the drive train, but acted as you describe. He was always very careful, very worried about service and all. He was driving across country moving a one way disc. So it was not being used hard.
But on a bigger Cat that was new to me, tilling a crescent moon shaped field. So using the clutch a lot for the gradual, but continues turn the springs finally gave up . They did not press the clutch plate hard enough to drive if the other side was disengaged.
So until it is taken apart no way to really know what you have.
2 years 4 months ago - 2 years 4 months ago #240477 by 3J1Bill
Looking at the photo of the steering clutch adjustment bolts, it looks like bolts need to be backed off some. It’s interesting that the bolts look like they have never been adjusted.  Make sure there is "free play" between the tip of the two bolts and the throw out arms. Just like a car clutch. Once you know the clutches have full spring pressure on them, you can pull back on the steering levers and feel the amount of pull it takes to move the levers back. When you are pulling back on a steering lever, you are feeling the amount of pressure that the springs are putting on the clutches. A light pull means thin worn clutches with expanded springs. Bill
Last edit: 2 years 4 months ago by 3J1Bill.
